[DONE] The New STM32F429/F439
Re: [TODO] The New STM32F429/F439
There are more changes than expected thanks to the new header...
X Tectu
Very interesting, VGA output using the new discovery.
Yep, that's indeed very interesting! Give me a working ChibiOS/RT on that board and I'll take care of the rest ;)
Well, the port is done and the demo compiles but OpenOCD 0.7.0 does not support the device yet so I am stuck, can anybody give it a try?
This is the OCD log:
Open On-Chip Debugger 0.7.0-dev-00079-g08ddb19 (2012-11-12-17:14)
Licensed under GNU GPL v2
For bug reports, read
   http://openocd.sourceforge.net/doc/doxygen/bugs.html
adapter speed: 1000 kHz
Warn : Interface already configured, ignoring
Error: already specified stlink_layout usb
srst_only separate srst_nogate srst_open_drain
Info : clock speed 1000 kHz
Info : stm32f4x.cpu: hardware has 6 breakpoints, 4 watchpoints
Info : accepting 'gdb' connection from 3333
Info : device id = 0x10036419
Warn : Cannot identify target as a STM32 family.
Error: auto_probe failed
Error: Connect failed. Consider setting up a gdb-attach event for the target to prepare target for GDB connect, or use 'gdb_memory_map disable'.
Error: attempted 'gdb' connection rejected
I just gave it a try and I don't have any issues to access the target MCU through OpenOCD 0.7.0
openocd -f interface/stlink-v2.cfg -f target/stm32f4xx_stlink.cfg
I could compile and flash the demo without any problems. However, it keeps hanging here forever:
while ((PWR->CSR & PWR_CSR_VOSRDY) == 0)
Looks like the voltage regulators never trigger the stable flag. Is it working for you, Giovanni?
I have not been able to flash the code so I didn't reach that point yet. Tomorrow I will give it another try.
Just a note,
Apparently it is not possible to run the CPU at 180MHz and obtain a 48MHz clock for USB... at least I have been unable to find a solution for that, the demo has been setup for a 168MHz clock.
I can try that later this night. Would I have to alter the PLL settings or is there some ready to use macro to set the frequency?
It is all about the PLL settings in mcuconf.h. There is no combination that yields 48MHz for the OTG when running at 180MHz, very strange they didn't foresee this.
Alternatively, I am missing something very obvious...
fractal
Been thanked: 5 times
Post by fractal »
I don't actually have a 429, but from what I read it seems the main PLL is unchanged from the 407 and similar. I can also not find a combination which would work, unless you can now increase the PLL clock to 720 MHz - in which case you could divide by 15 for USB and 4 for the CPU. There doesn't seem to be a macro yet.
