install studio in win 8 parallels VM
rocketdawg
Post by rocketdawg »
I had to install Java RT win32 version to get it to work. This is a 64 bit win 8 VM, but eclipse could not find the jre/bin/server/some.dll even though it was there.
that dir does not exist in the win32 java.
I also had to change the batch file
@echo off
cd \ChibiStudio
Something goofy with win 8 not honoring the "Start In:" directory in the shortcut.
I'd like to try the 4.7 version of GCC. Is it as simple as installing a new tool chain?
can I have both installed at the same time?
looking forward to using ChibiOS on the STF4 and I'd like to try getting it up on the LPC4330 dev board on both cores. What fun!
Re: install studio in win 8 parallels VM
You can simply replace the compiler in ChibiStudio and it will be fine, I do this already. You can have both and make the batch file point to the one you want to use.
Not sure about Win8, I am still with WinXP :) is it possible you just have to create a new shortcut using Win8?
rocketdawg
My home system Drive C:\ is somewhat full.
I did not want to install the studio on drive C:
but every path is absolute and starts with c:\
just a minor nit pic. I installed on C: anyway.
There are shell extensions able to create NTFS junctions (much like symbolic links), just create a link from C:\ChibiStudio to whatever you install the toolchain.
This one for example: https://sourceforge.net/projects/ntfslinkext/
