USB CDC - Force device mode
Hello folks,
I've once extracted the USB part into a separate file so I'm able to simply include it and get a shell working over USB CDC quickly. I'd now need to force my STM32F407 to be in device mode. There's the FDMOD bit in the OTG_FS_GUSBCFG register. I'm hard finding out how I can force the MCU to be in device mode using ChibiOS/RT. Can anyone give me a pointer? This is the actual code I took from the testhal:
#include "ch.h"
#include "shell.h"
#include "usb_cdc.h"
#include "usb_shell.h"
#include "chprintf.h"
SerialUSBDriver SDU1;
static const uint8_t vcom_device_descriptor_data[18] = {
  USB_DESC_DEVICE       (0x0110,        /* bcdUSB (1.1).                    */
                         0x02,          /* bDeviceClass (CDC).              */
                         0x00,          /* bDeviceSubClass.                 */
                         0x00,          /* bDeviceProtocol.                 */
                         0x40,          /* bMaxPacketSize.                  */
                         0x0483,        /* idVendor (ST).                   */
                         0x5740,        /* idProduct.                       */
                         0x0200,        /* bcdDevice.                       */
                         1,             /* iManufacturer.                   */
                         2,             /* iProduct.                        */
                         3,             /* iSerialNumber.                   */
                         1)             /* bNumConfigurations.              */
/* Device Descriptor wrapper */
static const USBDescriptor vcom_device_descriptor = {
   sizeof vcom_device_descriptor_data,
/* Configuration Descriptor tree for a CDC */
static const uint8_t vcom_configuration_descriptor_data[67] = {
  /* Configuration Descriptor.*/
  USB_DESC_CONFIGURATION(67,            /* wTotalLength.                    */
                         0x02,          /* bNumInterfaces.                  */
                         0x01,          /* bConfigurationValue.             */
                         0,             /* iConfiguration.                  */
                         0xC0,          /* bmAttributes (self powered).     */
                         50),           /* bMaxPower (100mA).               */
  /* Interface Descriptor.*/
  USB_DESC_INTERFACE    (0x00,          /* bInterfaceNumber.                */
                         0x00,          /* bAlternateSetting.               */
                         0x01,          /* bNumEndpoints.                   */
                         0x02,          /* bInterfaceClass (Communications
                                           Interface Class, CDC section
                                           4.2).                            */
                         0x02,          /* bInterfaceSubClass (Abstract
                                         Control Model, CDC section 4.3).   */
                         0x01,          /* bInterfaceProtocol (AT commands,
                                           CDC section 4.4).                */
                         0),            /* iInterface.                      */
  /* Header Functional Descriptor (CDC section 5.2.3).*/
  USB_DESC_BYTE         (5),            /* bLength.                         */
  USB_DESC_BYTE         (0x24),         /* bDescriptorType (CS_INTERFACE).  */
  USB_DESC_BYTE         (0x00),         /* bDescriptorSubtype (Header
                                           Functional Descriptor.           */
  USB_DESC_BCD          (0x0110),       /* bcdCDC.                          */
  /* Call Management Functional Descriptor. */
  USB_DESC_BYTE         (5),            /* bFunctionLength.                 */
  USB_DESC_BYTE         (0x01),         /* bDescriptorSubtype (Call Management
                                           Functional Descriptor).          */
  USB_DESC_BYTE         (0x00),         /* bmCapabilities (D0+D1).          */
  USB_DESC_BYTE         (0x01),         /* bDataInterface.                  */
  /* ACM Functional Descriptor.*/
  USB_DESC_BYTE         (4),            /* bFunctionLength.                 */
  USB_DESC_BYTE         (0x02),         /* bDescriptorSubtype (Abstract
                                           Control Management Descriptor).  */
  USB_DESC_BYTE         (0x02),         /* bmCapabilities.                  */
  /* Union Functional Descriptor.*/
  USB_DESC_BYTE         (0x06),         /* bDescriptorSubtype (Union
  USB_DESC_BYTE         (0x00),         /* bMasterInterface (Communication
                                           Class Interface).                */
  USB_DESC_BYTE         (0x01),         /* bSlaveInterface0 (Data Class
                                           Interface).                      */
  /* Endpoint 2 Descriptor.*/
  USB_DESC_ENDPOINT     (USB_CDC_INTERRUPT_REQUEST_EP|0x80,
                         0x03,          /* bmAttributes (Interrupt).        */
                         0x0008,        /* wMaxPacketSize.                  */
                         0xFF),         /* bInterval.                       */
  USB_DESC_INTERFACE    (0x01,          /* bInterfaceNumber.                */
                         0x02,          /* bNumEndpoints.                   */
                         0x0A,          /* bInterfaceClass (Data Class
                                           Interface, CDC section 4.5).     */
                         0x00,          /* bInterfaceSubClass (CDC section
                                           4.6).                            */
                         0x00,          /* bInterfaceProtocol (CDC section
                                           4.7).                            */
                         0x00),         /* iInterface.                      */
  /* Endpoint 3 Descriptor.*/
  USB_DESC_ENDPOINT     (USB_CDC_DATA_AVAILABLE_EP,     /* bEndpointAddress.*/
                         0x02,          /* bmAttributes (Bulk).             */
                         0x0040,        /* wMaxPacketSize.                  */
                         0x00),         /* bInterval.                       */
  /* Endpoint 1 Descriptor.*/
  USB_DESC_ENDPOINT     (USB_CDC_DATA_REQUEST_EP|0x80,  /* bEndpointAddress.*/
                         0x00)          /* bInterval.                       */
/* Configuration Descriptor wrapper */
static const USBDescriptor vcom_configuration_descriptor = {
   sizeof vcom_configuration_descriptor_data,
/* U.S. English language identifier */
static const uint8_t vcom_string0[] = {
   USB_DESC_BYTE(4),                     /* bLength.                         */
   USB_DESC_BYTE(USB_DESCRIPTOR_STRING), /* bDescriptorType.                 */
   USB_DESC_WORD(0x0409)                 /* wLANGID (U.S. English).          */
/* Vendor string */
static const uint8_t vcom_string1[] = {
   USB_DESC_BYTE(38),                    /* bLength.                         */
   'S', 0, 'T', 0, 'M', 0, 'i', 0, 'c', 0, 'r', 0, 'o', 0, 'e', 0,
   'l', 0, 'e', 0, 'c', 0, 't', 0, 'r', 0, 'o', 0, 'n', 0, 'i', 0,
   'c', 0, 's', 0
/* Device Description string */
static const uint8_t vcom_string2[] = {
   USB_DESC_BYTE(56),                    /* bLength.                         */
   'C', 0, 'h', 0, 'i', 0, 'b', 0, 'i', 0, 'O', 0, 'S', 0, '/', 0,
   'R', 0, 'T', 0, ' ', 0, 'V', 0, 'i', 0, 'r', 0, 't', 0, 'u', 0,
   'a', 0, 'l', 0, ' ', 0, 'C', 0, 'O', 0, 'M', 0, ' ', 0, 'P', 0,
   'o', 0, 'r', 0, 't', 0
/* Serial Number string */
static const uint8_t vcom_string3[] = {
   USB_DESC_BYTE(8),                     /* bLength.                         */
   '0' + CH_KERNEL_MAJOR, 0,
   '0' + CH_KERNEL_MINOR, 0,
   '0' + CH_KERNEL_PATCH, 0
/* Strings wrappers array */
static const USBDescriptor vcom_strings[] = {
   {sizeof vcom_string0, vcom_string0},
   {sizeof vcom_string1, vcom_string1},
   {sizeof vcom_string2, vcom_string2},
   {sizeof vcom_string3, vcom_string3}
static const USBDescriptor *get_descriptor(USBDriver *usbp, uint8_t dtype, uint8_t dindex, uint16_t lang) {
   (void)usbp;
   (void)lang;
   switch (dtype) {
      case USB_DESCRIPTOR_DEVICE:
         return &vcom_device_descriptor;
      case USB_DESCRIPTOR_CONFIGURATION:
         return &vcom_configuration_descriptor;
      case USB_DESCRIPTOR_STRING:
         if(dindex < 4)
         return &vcom_strings[dindex];
   return NULL;
static USBInEndpointState ep1instate;
static USBOutEndpointState ep1outstate;
static const USBEndpointConfig ep1config = {
   USB_EP_MODE_TYPE_BULK,
   NULL,
   sduDataTransmitted,
   sduDataReceived,
   0x0040,
   0x0040,
   &ep1instate,
   &ep1outstate,
   2,
   NULL
static USBInEndpointState ep2instate;
static const USBEndpointConfig ep2config = {
   USB_EP_MODE_TYPE_INTR,
   NULL,
   sduInterruptTransmitted,
   NULL,
   0x0010,
   0x0000,
   &ep2instate,
   NULL,
   1,
   NULL
static void usb_event(USBDriver *usbp, usbevent_t event) {
   switch (event) {
      case USB_EVENT_RESET:
         return;
      case USB_EVENT_ADDRESS:
         return;
      case USB_EVENT_CONFIGURED:
         chSysLockFromIsr();
         /* Enables the endpoints specified into the configuration.
          * Note, this callback is invoked from an ISR so I-Class functions
          * must be used.
         usbInitEndpointI(usbp, USB_CDC_DATA_REQUEST_EP, &ep1config);
         usbInitEndpointI(usbp, USB_CDC_INTERRUPT_REQUEST_EP, &ep2config);
         /* Resetting the state of the CDC subsystem.*/
         sduConfigureHookI(usbp);
         chSysUnlockFromIsr();
         return;
      case USB_EVENT_SUSPEND:
         return;
      case USB_EVENT_WAKEUP:
         return;
      case USB_EVENT_STALLED:
         return;
   return;
const USBConfig usbcfg = {
   usb_event,
   get_descriptor,
   sduRequestsHook,
   NULL
const SerialUSBConfig serusbcfg = {
   &USBD1
BaseSequentialStream* usbShellInit(void) {
   sduObjectInit(&SDU1);
   sduStart(&SDU1, &serusbcfg);
   chThdSleepMilliseconds(1000);
   return (BaseSequentialStream*)&SDU1;
Thanks in advance,
Re: USB CDC - Force device mode
You don't need to force anything, it is done inside the driver.
The reason I need to force it is because I don't have any ID line connected.
By "it's done inside the driver" you don't mean the code I showed, or do you try to tell me that I'm already forcing it into device mode?
It is already forced in device mode.
Jep, it's definitely working. Thank you very much for your help!
