IRDA over Serial on STM32F103
Selrak
Post by Selrak »
Hey all,
So I have two systems, each with an IRDA emitter/receiver/transceiver soldered to UART pins on an STM32F103, along with a general purpose serial output which I plug into my computer for debug purposes.
Now I can't get these to communicate ! I have setup both serials, one with a regular 9600 bauds/sec config, the other with the same rate but with the "UART_CR3_IREN" mask on the last SerialConfig structure member, and made sure the "ShutDown" pin on my IRDA device was cleared. What am I missing ? Or should I look for board.h definition errors ?
Note : the macro at the beginning changes the behavior from IRDA emitter to IRDA receiver. The receiver sends 'r' after every 5 sec timeout on the IRDA serial, the emitter just sends 'x' all the time.
Note 2 : I do receive the receiver's 'r's (along with an unknown character) every 5 seconds. But no 'x' ...
Thanks in advance for the tips and help ! You guys rock and I love Chibi.
#include "ch.h"
#define EMITTER 1
// Serial configs : enable IRDA for one, and use a normal config for the other
static const SerialConfig irda_cfg = {9600, 0, 0, USART_CR3_IREN};
static const SerialConfig normal_cfg = {9600, 0, 0, 0};
int main (void) {
        // Make sure IRDA is on (ShutDown at 0)
        palClearPad(GPIOA, SD_IRDA2);
        // IRDA2 on PC10/11 through USART3
        sdStart(&SD3, &irda_cfg);
        // Output serial
        sdStart(&SD1, &normal_cfg);
        while(1) {
                if(EMITTER) {
                        sdPut(&SD3, 'x');
                else {
                        sdPut(&SD1, 'r');
                        sdPut(&SD1, sdGetTimeout(&SD3, 5000));
Re: IRDA over Serial on STM32F103
Are the TX pins of both USARTs configured as alternate in your board.h file? try watching the TX signals using a scope or a logic analyzer.
