I'm using ChibiOS/RT 2.2.3 with ATMega128A and AVR-GCC 4.3.3 (WinAVR 20100110).
There is error in source code in serial_llc.c in AVR port.
At line 192, SER1 should be SD1.
The USART0 is not working under the 38400bps.
There is no output at USART0 under the 38400bps.
Serial Problem in AVR
Moderator: tfAteba
Re: Serial Problem in AVR
Thanks for reporting this problem, I will verify it and open a ticket.
kimgunzung
It is a problem of UBRR macro.
The AVR-GCC make warning "large integer implicitly truncated to unsigned type".
I modify UBRR macro such as below. This has no problem and no warning.
#define UBRR(b) (((F_CPU / b) >> 4) - 1)
Thanks for the fix, I didn't notice any warning, probably I am using an old version of AVR-GCC, time to upgrade it. I'll commit your change.
