Hi all,
So I will soon be working on a custom board that has an STM32F405. So in order to prepare my work I just started building the board directory with the board.c and board.h files. To begin with, I copied those from the classic ST_STM32F4_DISCOVERY board. As I first compiled the (pretty much empty) project, ChibiOS told me there was an #error : "STM32_PCLK1 exceeding maximum frequency (STM32_PCLK1_MAX)". Now I saw those values and how the clock speed got defined in the os/hal/platforms/STM32F4xx/hal_lld.h, but I don't know what to change : is it the maximum speed that's wrong, or is it the defined speed ? I suppose I can go check out the manuals and datasheets for the STM32F405 just to see what values should be there, but if you already know of this problem, then great - and I thought I'd let you know, because it seems to come from one of Chibi's predefined boards, so any user will have this problem.
Cheers,
Charles
EDIT : Here's what I understood. Specifically, it's the APB1 frequency (STM32_PCLK1) Chibi is not happy with. In the ST_STM32F4_DISCOVERY board all that's defined is STM32_HSE (value : 8 MHz), which is then transmitted with a certain prescaler to STM32_SYSCLK which is then transmitted with a certain prescaler to STM32_HCLK which is then transmitted with a certain prescaler to STM32_PCLK1 - that's how it should happen right ? And when you look at the figures (STM32_PCLK1_MAX is 42 MHz when STM32F4XX is defined), you realize even if you don't divide HSE at all it's still clearly small enough.
EDIT EDIT : Actually, there's more to it. By default, STM32_SYSCLK receives STM32_PLLCLKOUT rather than directly STM32_HSECLK. STM32_PLLCLKOUT is calculated from PLL characteristics and STM32_PLLCLKIN, which itself comes from STM32_HSECLK. I still don't see how it managed to be too big. Help !
Excessive clock speed in predefined board
Re: Excessive clock speed in predefined board
Probably your board has an higher crystal frequency, all you have to change is PLL settings in the mcuconf.h file of your application. If you post the crystal value then I could suggest changes, alternatively refer to the STM32 Reference Manual for details about those settings.
Indeed, the problem was in the mcuconf.h as you suggested. Thanks a lot !
Charles
Charles
