[DONE] stm32f0 RTC support
cdrttn
Post by cdrttn »
I'm trying to use the RTC on my stm32f0 chip with the latest trunk version of ChibiOS, but it seems that STM32F0xx/platform.mk doesn't include the common STM32 RTC code, and i'm getting the error "../../os/hal/include/rtc.h:76:21: fatal error: rtc_lld.h: No such file or directory" when I try to build with HAL_USE_RTC set to true. The other STM32 platforms build with either RTCv1 or RTCv2. Is stm32f0's RTC incompatible with existing code?
Re: stm32f0 RTC support
The RTC driver is not yet tested on the F0 this is why it is not present in platform.mk, you may try to add there the RTCv2 and see if something else is missing.
cdrttn
Post by cdrttn »
Hey
Added RTCv2 like this:
diff --git a/os/hal/platforms/STM32F0xx/platform.mk b/os/hal/platforms/STM32F0xx/platform.mk
index c04d85c..a949036 100644
--- a/os/hal/platforms/STM32F0xx/platform.mk
+++ b/os/hal/platforms/STM32F0xx/platform.mk
@@ -11,6 +11,7 @@ PLATFORMSRC = ${CHIBIOS}/os/hal/platforms/STM32F0xx/stm32_dma.c \
               ${CHIBIOS}/os/hal/platforms/STM32/I2Cv2/i2c_lld.c \
               ${CHIBIOS}/os/hal/platforms/STM32/SPIv2/spi_lld.c \
               ${CHIBIOS}/os/hal/platforms/STM32/USARTv2/serial_lld.c \
+              ${CHIBIOS}/os/hal/platforms/STM32/RTCv2/rtc_lld.c \
               ${CHIBIOS}/os/hal/platforms/STM32/USARTv2/uart_lld.c
 # Required include directories
@@ -19,4 +20,5 @@ PLATFORMINC = ${CHIBIOS}/os/hal/platforms/STM32F0xx \
               ${CHIBIOS}/os/hal/platforms/STM32/GPIOv2 \
               ${CHIBIOS}/os/hal/platforms/STM32/I2Cv2 \
               ${CHIBIOS}/os/hal/platforms/STM32/SPIv2 \
+              ${CHIBIOS}/os/hal/platforms/STM32/RTCv2 \
Build goes a little farther, but this new error pops up:
Compiling hal.c
In file included from ../../os/hal/include/rtc.h:76:0,
from ../../os/hal/include/hal.h:56,
from ../../os/hal/src/hal.c:30:
../../os/hal/platforms/STM32/RTCv2/rtc_lld.h:85:2: error: #error "STM32_PCLK1 frequency is too low to handle RTC without ugly workaround"
Any ideas?
Thanks
cdrttn
Post by cdrttn »
Also here is my configuration: https://github.com/cdrttn/clock
The board is very similar to the F0 Discovery, with the only significant difference being that it has a 32khz external oscillator.
talsit
Post by talsit »
Did you ever get the RTC working on the STM32F0?
What do you do to get STM32_PCLK1?
DeusExMachina
Has thanked: 3 times
Post by DeusExMachina »
what is the current situation with RTC driver on stm32F0 platform?
DeusExMachina
self-reply - everything in driver seems to be OK )
DeusExMachina
Heh, it was too good to be true...
I can't get RTC alarm using RTC and EXTI drivers. What could be wrong?
static void extcb2(EXTDriver *extp, expchannel_t channel)
  (void)extp;
  (void)channel;
  palTogglePad(GPIOC, GPIOC_LED4);
  chSysUnlockFromIsr();
    {EXT_CH_MODE_DISABLED, NULL},
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, extcb2},
RTCAlarm alarm;
struct tm timp;
 * Application entry point.
int main(void) {
   * System initializations.
   *   RTOS is active.
  timp.tm_year = 114;
  timp.tm_mon = 2;
  timp.tm_mday = 11;
  timp.tm_hour = 8;
  timp.tm_min = 44;
  timp.tm_wday = 1;
  rtcSetTimeTm(&RTCD1, &timp);
  int i = 10; //secs
  alarm.tv_datetime = ((i / 10) & 7 << 4) | (i % 10) | RTC_ALRMAR_MSK4 | RTC_ALRMAR_MSK3 | RTC_ALRMAR_MSK2; // from testhal example for F4
  rtcSetAlarm(&RTCD1, 0, &alarm);
   * Activates the EXT driver 1.
  extStart(&EXTD1, &extcfg);
My board is stm32F0Discovery
DeusExMachina
I have found a bug in a rtc driver. stm32f0 has 1 alarm unit. But in 125 line in rtc.c we have
  chDbgCheck((rtcp != NULL) && (alarm < RTC_ALARMS), "rtcSetAlarm");
RTC_ALARMS for STM32F0 is 1.
If we use 0 as second argument for rtcSetAlarm we miss the code in rtc_lld_set_alarm
  if (alarm == 1){
#if RTC_ALARMS == 2
  else{
If we use 1 we are cached by debug check.
Adding to the TODO list.
