GCC errors while compiling demos
fjrg76
Post by fjrg76 »
Hi
While trying to compile the ChibioOS demos I got the same error among them. First I tried inside Eclipse, and then in a console (Win 7), and the error is the same:
C:\Development\ChibiOS_2.4.3\demos\ARMCM3-STM32F100-DISCOVERY>make
[b]El sistema no puede encontrar la ruta especificada[/b]. (Translation: System can't find the path.)
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m3 -O0 -ggdb -fomit-frame-poi
ections -fdata-sections -fno-common  -Wall -Wextra -Wstrict-pro
=build/lst/   -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_I
MP -MF .dep/build.d -I. -I../../os/ports/common/ARMCMx/CMSIS/in
ports/common/ARMCMx -I../../os/ports/GCC/ARMCMx -I../../os/port
2F1xx -I../../os/kernel/include -I../../test -I../../os/hal/inc
al/platforms/STM32F1xx -I../../os/hal/platforms/STM32 -I../../o
TM32/GPIOv1 -I../../os/hal/platforms/STM32/USBv1 -I../../os/hal
RTCv1 -I../../boards/ST_STM32VL_DISCOVERY -I../../os/various ma
ECHO está desactivado. (Translation: ECHO is disabled.)
mkdir -p build/obj
[b]La sintaxis del comando no es correcta.[/b] (Translation: Command syntaxis is not correct.)
make: *** [build] Error 1
Some facts:
    This is my first time with this OS
    OS guest: Win7
    Toolchain: Code Sourcery -> gcc version 4.7.2 (Sourcery CodeBench Lite 2012.09-63)
What am I missing? Shure it's a silly mistake.
Thank you!!
Abhishek
Re: GCC errors while compiling demos
Post by Abhishek »
Check if your PATH variable has been set correctly. type PATH on the command prompt and you should see somewhere:
C:\Program Files (x86)\... Sourcery G++ Lite\bin or something of that sort.
If not, you will have to manually add it to your PATH using PATH <path-to-code-sourcery>;%PATH% .
Secondly, to build with CodeSourcery, the command to be used is 'cs-make' and not 'make'. The make might be due to another compiler you have installed on the system.
Try out the changes and let us know.
Regards
Abhishek
fjrg76
Post by fjrg76 »
Hi
My path looks like:
C:\ARMGNU\bin;C:\Ruby200\bin;c:\;%SystemRoot%\system32;%SystemRoot%;%SystemRoot%\System32\Wbem;C:\Archivos de programa\Flash Magic;C:\gtk2.24;C:\Archivos de programa\Calibre2\
As seen, the very first entry is the Code Sourcery tool chain.
An interestig fact is that I downloaded the ChibiStudio and it compiled the demos off-the-shelf. Then I moved a project out the main tree, I updated the Makefile accordingly, and it compiled again.
ChibiStudio includes its own toolchain (Yagarto), so as Abhishek said, it might a toolchain's path. I also tried with "cs-make" and I still had the same problem.
C:\ChibiStudio\ARMCM3-STM32L152-DISCOVERY>[b]cs-make --version[/b]
[i]GNU Make (Sourcery CodeBench Lite 2012.09-63) 3.81[/i]
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i686-pc-mingw32
Last interesting fact so far is that although I can compile with "make" or "cs-make", neither of them can execute a "make clean". A quick and dirt workaround is to "touch" the Makefile.
By the way, how can I now the binary size in bytes? Playing around with FreeRTOS the binary size was 52KB, even without any thread coded !! Maybe the real size is not as bigger as that, so I'm pretty shure there might a way to know it.
Thank you!!
Just look at the size of the compiled size ch.bin, the size of that file is the whole size in Flash. Alternatively you can look into the ch.map file which will give all details about memory usage.
I still think your problem is caused by the make program, ChibiStudio works because it *enforces* the use of its internal make.
fjrg76
Post by fjrg76 »
Hi
I'm still not able to do a "make clean", however I can compile and upload my code, which is most important.
Yes, I figure out that the .bin file is closed to the soruce size. Now you confirm my suspects.
Thank you for your time and effort !!
fjrg76
Post by fjrg76 »
Hi
While still trying to make the "make" command to work I realized that this is not a PATH problem 'cause even with the whole path written the problem is still there:
C:\ChibiOS_2.4.3\demos\ARMCM3-GENERIC-KERNEL>c:\ChibiStudio\tools\yagarto-tools\bin\make
El sistema no puede hallar la ruta especificada.
Compiler Options
arm-none-eabi-gcc -c -mcpu=cortex-m3 -O2 -ggdb -fomit-frame-pointer -ffunction-s
ections -fdata-sections -fno-common  -Wall -Wextra -Wstrict-prototypes -Wa,-alms
=build/lst/ -DSTM32F10X_MD  -DTHUMB_PRESENT -mno-thumb-interwork -DTHUMB_NO_INTE
RWORKING -MD -MP -MF .dep/build.d -I. -I../../os/ports/common/ARMCMx/CMSIS/inclu
de -I../../os/ports/common/ARMCMx -I../../os/ports/GCC/ARMCMx -I../../os/ports/G
CC/ARMCMx/STM32F1xx -I../../os/kernel/include -I../../os/various main.c -o main.o
mkdir -p build/obj
However, as I said before, inside the "ChibiosStudio" workspace the "make" command works as expected. Any idea?
Or even better, may you lead me to the instructables for porting the projects in the ChibiOS tree to the ChibiosStudio one?
Thank you!!
Because ChibiStudio *enforces* its internal make.exe.
Remove the defective make or reorder your PATH variable.
fjrg76
Post by fjrg76 »
Hi
I deleted a CodeBlocks installation that in turns installed MinGW, and I still am not able to compile outside ChibiStudio workspace. Nevertheless, it's time to move on, I think I can live with this situation.
Thank you!!
marcinj7
Post by marcinj7 »
Hi
The problem is with the last command mkdir -p build/obj.
Check if mkdir create this folder, if not windows 7 don't allow mkdir to create it.
fjrg76
Post by fjrg76 »
marcinj7 wrote:Hi
Sadly it doesn't compile the projects in XP as well (from the command line; inside ChibiStudio-Eclipse it does). But I really don't need to compile from the command line, so it's ok doing it from inside Eclipse.
Thank you!!
