!defined unknown to uvision4 for ARM?
Guanahani
Post by Guanahani »
Hello Giovanni,
i am trying to rebuild the example : ARMCM3-STM32F103 for Keil using ChibiOS 2.2.4
Target is an Olimex STM32-H107. I have customized the files in OLIMEX_STM32_P103 into
a new OLIMEX_STM32-H107 subdir in boards.
Copied the ARMCM3-STM32F103 into a new project folder and adapted
- halconf.h
- mcuconf.h
to my needs. I am planning to use all 3 SPI and USARTS 2 and 3 of the STM32F107VC.
Also changed the path to the board subdir in the Keil project.
All things went easy, so far.
Using the demo version of the Keil compiler i have tried to compile the project and first
found the problem with the clock generation and corrected it as proposed in the forum.
When i try to compile now i am getting following warnings :
..\..\..\os\hal\platforms\STM32\uart_lld.h(86): warning: #47-D: incompatible redefinition of macro "STM32_UART_USART1_IRQ_PRIORITY" (declared at line 124 of "..\mcuconf.h")
..\..\..\os\hal\platforms\STM32\uart_lld.h(93): warning: #47-D: incompatible redefinition of macro "STM32_UART_USART2_IRQ_PRIORITY" (declared at line 125 of "..\mcuconf.h")
..\..\..\os\hal\platforms\STM32\uart_lld.h(100): warning: #47-D: incompatible redefinition of macro "STM32_UART_USART3_IRQ_PRIORITY" (declared at line 126 of "..\mcuconf.h")
Project build/rebuild aborted.
I have changed the USART irq to 11, which should be OK because i do not using CAN.
Following this warnings i have consulted the Keil Manual and made some tests finding that the preprocessor
does not allow the syntax :
#if !defined(STM32_UART_USART1_IRQ_PRIO) || defined(__DOXYGEN__)
The preprocessor just misinterprets the line which is always not true, so the warning
is generated because default irq in uart_lld.h is 12.
I have found 256 occurrences of the !defined in the code.
Keil manual describes only #ifdef and #ifndef statements, so all occurances mut be replaced by nested
#ifdef and #ifndef.
Thank you for your help.
Re: !defined unknown to uvision4 for ARM?
The first problem has been fixed in 2.2.5, the other problem is not because the defined() (which is standard and perfectly fine) but because an error in uart_lld.h:
#if !defined(STM32_UART_USART2_IRQ_PRIO) || defined(__DOXYGEN__)
#define STM32_UART_USART2_IRQ_PRIORITY 12
Note that the check is performed on a different name, "PRIO" instead of "PRIORITY". I'll fix this in 2.2.6, in the meanwhile you can manually fix uart_lld.h by putting the correct macro names inside the !defined().
Thanks for finding this problem.
