[INFO] Statistics Module in ChibiOS/RT 3.0
A small update, after the tickless mode, the statistics module is ready too, few images:
Threads View
Threads View
Note that the thread consumed time is measured in cycles (64bits counter) and the thread worst code path is also calculated in cycles.
Statistics Vies
Statistics Vies
The worst case for critical zones is also measured in cycles.
The statistics module is meant to make system characterization easier for end users with strong hard-realtime requirements. Note that the kernel is running in tickless mode so the total number of interrupts is in the tens instead of the ten thousands after few seconds of runtime.
Prof. Dr. YoMan
Re: [INFO] Statistics Module in ChibiOS/RT 3.0
Post by Prof. Dr. YoMan »
Nice! Both very welcome additions.
When do you expect 3.0 to be released. What is your target?
Next year probably, there is still a lot to do, especially in the HAL.
This is very nice!
Are those features also usable without eclipse?
You can inspect the variables using the debugger.
