how to get state in eclipse plugin?
russian
Has thanked: 16 times
Been thanked: 14 times
Post by russian »
Search does not want to search by "eclipse plugin" since the words are too common so please excuse me for posting a banal question.
I have copied two jars into the eclipse/plugin folder and Eclipse does show the ChibiOS/RT window
I have arm-none-eabi-gdb.exe gdb setup with openocd - I can set breakpoints, pause resume etc - so, debugging does function.
But the plugin does not show me any data, even if I click the refresh button. What am I missing? Am I supposed to setup something else somewhere? Any configuration option in the compiled code? I believe I have most if not all *_DBG_* options enabled. I feel like I am missing something very simple here :)
Re: how to get state in eclipse plugin?
Make sure to have the following setting:
Note that the plugin will be able to show you info only after the target executed chSysInit() and while the program is stopped.
russian
Post by russian »
Yes, this option did the job!
As a usability improvement the plugin can show a message like 'please make sure standard launcher is active' if it detects the lack of data.
Thank you for your patience with us :)
