chEvtWaitAny and Syslock
i'm a little confused about the chEvtWaitAny (chThdYield and chThdSleep). When i call one of those functions the System will go into chSysLock. For the in parallel running Thread the System is still locked until the Thread which performed the chEvtWaitAny/chThdYield/chThdSleep will be waked up.
So if the in parallel running Thread wants to perform a canStart() the debug Error SV#4 will occur.
Regards,
Florian
Regards,
Florian
Re: chEvtWaitAny and Syslock
When the system goes in a context switch function (chthdSleep for example) the lock primitive is invoked before going to sleep and the unlock is immediately invoked by the next thread executed.
The sequence is always: lock - switch - unlock-
If you get an #SV4 then you have some call protocol violation somewhere.
i located the error at wrong position. After PIT Initialization an interrupt will be called by the SYSIrqHandler. There I get an SV#8.
vt_systime: 1
r_current: 00201208 "idle"
r_preempt: 20
dbg_isr_cnt: not within ISR
dbg_lock_cnt: within lock
Why do a get an interrupt while in lock?
Regards,
Florian
vt_systime: 1
r_preempt: 20
Regards,
Florian
Are your IRQ priorities within allowed ranges? if you have some priority above the max then it can preempt even in a lock. I am assuming you are talking about a Cortex, you gave no context.
the prorities are like in board.c defined highest - 1. We are on a AT91SAM7X256 (board by olimex).
from board.c:
* PIT Initialization.
AIC_ConfigureIT(AT91C_ID_SYS,
AT91C_AIC_SRCTYPE_HIGH_LEVEL | (AT91C_AIC_PRIOR_HIGHEST - 1),
SYSIrqHandler);
AIC_EnableIT(AT91C_ID_SYS);
AT91C_BASE_PITC->PITC_PIMR = (MCK / 16 / CH_FREQUENCY) - 1;
AT91C_BASE_PITC->PITC_PIMR |= AT91C_PITC_PITEN | AT91C_PITC_PITIEN;
I even have that problem with an empty main loop.
from board.c:
SYSIrqHandler);
i think i found the cause of the SV#4. After creating a thread we used chSchDoReschedule() instead of chThdYield(). But why doesn't chSchDoReschedule() work?
Regards,
Florian
Regards,
Florian
From the function description: "Not a user function, it is meant to be invoked by the scheduler itself or from within the port layer.".
Why you need to reschedule after creating a thread? this is not required usually.
I have a thread which does some CAN initialisation. This is needed later on in the main thread. So i just wait until the CAN-Thread is ready. To not suck in a while, which does nothing, i want to yield execution to the CAN thread.
I had other situations where I just wanted to ensure that the thread was active at least once.
"Not a user function" - I'm a giddy Goat
Regards,
Florian
Regards,
Florian
You may just give the CAN thread an higher priority, the effect would be the same without relying on the round-robin behavior.
