[INFO] ChibiOS 3.0 Status
A small update, the new kernel is almost done, the new HAL is progressing well. I am still meditating about some internal interfaces but nothing important should change.
Now it is mainly matter of reintegrating all the ports, the platforms and the demos in the new branch doing the necessary changes. So far STM32F0xx and STM32F30x have been reintegrated and tested. The whole operation may require months but it is progressing smoothly.
Maintainers may want to check the changes in the new branch and start planning the port of the existing platforms. Porting a driver is very simple:
1) Remove the inclusion of ch.h
2) Replace all the calls to ChibiOS/RT APIs with the equivalent APIs in the OSAL layer (almost equal with a different prefix "osal" or "OSAL_").
3) Test the ported driver, it never happened that one didn't work so far.
4) Change the references to NVIC functions, now the priority is passed directly.
Re: [INFO] ChibiOS 3.0 Status
Added initial support for the F4, drivers to be re-tested.
May one be able to help testing without needing all the deep knowledge as the platform maintainer does?
Using it in some real application but that could be too early.
Prof. Dr. YoMan
Post by Prof. Dr. YoMan »
Just digging around, found this:
#define STM_OK               Q_OK
#define STM_TIMEOUT          Q_RESET
#define STM_RESET            Q_TIMEOUT
in hal_streams.h. Guess not ok.
Thanks, fixed :)
I expect this kind of errors, the code is solid already.
russian
Has thanked: 16 times
Been thanked: 14 times
Post by russian »
It has been some time since the 3.0 status was updated... How does it look? :)
It looks very good and already usable :)
Not all ports have been ported to 3.0 but what is there is usable. Probably there will not be a 2.7.0.
russian
Post by russian »
Do you have any specific date, or maybe some specific month, or at least some specific year for the 3.0 release? :)
Sure, 2014 :)
