ADC-UART Problem
fischer
ADC-UART Problem
Post by fischer »
Hi, I am new in the chibios world and I have a problem. I try to read with my stm32f3_discovery board an adc value and send it via uart to my pc .
The controller reads the value when I press the user button. The Uart-Conversation usually works, I can send normal integer values to my pc, but when i activate the adc the programm stop running when it comes to the function "adcConvert". Has somebody any idea ?
There is also another question about the ADC. I only use the ADC3 but for my Project i need more adcs. How can I use the ADC2 on Pin 5 as example ?
Main:
#include "ch.h"
#define ADC_GRP1_NUM_CHANNELS   1
#define ADC_GRP1_BUF_DEPTH      4
int wertg = 3453; // ADC value
int flag=0;
int flag2=0;
char x [6];
static VirtualTimer vt1, vt2;
static adcsample_t samples1[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
//Interrupt
static void restart(void *p) {
  (void)p;
  flag=1;
  if (flag2==1){
    // convert the value of the adc to a char ,for sending
                            x[0]=(char)(((wertg%10000)/1000)+48);
                            x[1]=(char)(((wertg%1000)/100)+48);
                            x[2]=(char)(((wertg%100)/10)+48);
                            x[3]=(char)((wertg%10)+48);
                            x[4]='\r';
                            x[5]='\n';
  palClearPad(GPIOE, GPIOE_LED10_RED);
  chSysLockFromIsr();
  uartStartSendI(&UARTD1, 6, x);
  chSysUnlockFromIsr();
  flag2=0;
static void adcerrorcallback(ADCDriver *adcp, adcerror_t err) {
  (void)adcp;
  (void)err;
// ADC init
static const ADCConversionGroup port1 = {
  FALSE,
  ADC_GRP1_NUM_CHANNELS,
  NULL,
  adcerrorcallback,
  0,                        /* CFGR    */
  ADC_TR(0, 4095),          /* TR1     */
  0,                        /* CCR     */
  {                         /* SMPR[2] */
    0,
    0
  {                         /* SQR[4]  */
    ADC_SQR1_SQ1_N(ADC_CHANNEL_IN7), //| ADC_SQR1_SQ2_N(ADC_CHANNEL_IN8),
    0,
    0,
    0
 * This callback is invoked when a transmission buffer has been completely
 * read by the driver.
static void txend1(UARTDriver *uartp) {
  (void)uartp;
  palSetPad(GPIOE, GPIOE_LED3_RED);
 * This callback is invoked when a transmission has physically completed.
static void txend2(UARTDriver *uartp) {
  (void)uartp;
 * This callback is invoked on a receive error, the errors mask is passed
 * as parameter.
static void rxerr(UARTDriver *uartp, uartflags_t e) {
  (void)uartp;
  (void)e;
 * This callback is invoked when a character is received but the application
 * was not ready to receive it, the character is passed as parameter.
static void rxchar(UARTDriver *uartp, uint16_t c) {
  (void)uartp;
  (void)c;
 * This callback is invoked when a receive buffer has been completely written.
static void rxend(UARTDriver *uartp) {
  (void)uartp;
 * UART driver configuration structure.
static UARTConfig uart_cfg_1 = {
  txend1,
  txend2,
  rxend,
  rxchar,
  rxerr,
  38400,
  0,
  USART_CR2_LINEN,
  0
 * Application entry point.
static void extcb1(EXTDriver *extp, expchannel_t channel) {
  static VirtualTimer vt4;
  (void)extp;
  (void)channel;
  palSetPad(GPIOE, GPIOE_LED10_RED);
  chSysLockFromIsr();
  if (chVTIsArmedI(&vt4))
    chVTResetI(&vt4);
  /* LED4 set to OFF after 200mS.*/
  chVTSetI(&vt4, MS2ST(200), restart, NULL);
    {EXT_CH_MODE_BOTH_EDGES | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOA, extcb1},
    {EXT_CH_MODE_DISABLED, NULL},
static WORKING_AREA(waadc, 128);
static msg_t adc(void*arg)
  (void)arg;
  chRegSetThreadName("ADC");
  while(1)
    if(flag==1)
               flag2=1;
               adcConvert(&ADCD3, &port1, samples1, ADC_GRP1_BUF_DEPTH);    // get the value of the adc
               wertg=samples1[0];                                           //give the value of the ADC to a global variable
                 flag=0;
    chThdSleepMilliseconds(10);
int main(void) {
   * System initializations.
   *   RTOS is active.
   * Activates the serial driver 1, PA9 and PA10 are routed to USART1.
  uartStart(&UARTD1, &uart_cfg_1);
  palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7));       /* USART1 TX.       */
  palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7));      /* USART1 RX.       */
  palSetGroupMode(GPIOD, PAL_PORT_BIT(10),
  0, PAL_MODE_INPUT_ANALOG); // init the GPIO D10 PIN as ADC
  chThdCreateStatic(waadc, sizeof(waadc),NORMALPRIO, adc, NULL); // create thread
  uartStartSend(&UARTD1, 7, "Start\r\n");// send for testing
  extStart(&EXTD1, &extcfg);// for external interrupt
  extChannelEnable(&EXTD1, 0);//
  adcStart(&ADCD3, NULL); // start the ADC34
   * Normal main() thread activity, in this demo it does nothing.
  while (TRUE) {
    chThdSleepMilliseconds(500);
halconf.h:
 ChibiOS/RT - Copyright (C) 2006-2013 Giovanni Di Sirio
 * @file    templates/halconf.h
 * @brief   HAL configuration header.
 * @details HAL configuration file, this file allows to enable or disable the
 *          various device drivers from your application. You may also use
 *          this file in order to override the device drivers default settings.
 * @addtogroup HAL_CONF
#ifndef _HALCONF_H_
#define _HALCONF_H_
#include "mcuconf.h"
 * @brief   Enables the TM subsystem.
#if !defined(HAL_USE_TM) || defined(__DOXYGEN__)
#define HAL_USE_TM                  FALSE
 * @brief   Enables the PAL subsystem.
#if !defined(HAL_USE_PAL) || defined(__DOXYGEN__)
#define HAL_USE_PAL                 TRUE
 * @brief   Enables the ADC subsystem.
#if !defined(HAL_USE_ADC) || defined(__DOXYGEN__)
#define HAL_USE_ADC                 TRUE
 * @brief   Enables the CAN subsystem.
#if !defined(HAL_USE_CAN) || defined(__DOXYGEN__)
#define HAL_USE_CAN                 FALSE
 * @brief   Enables the EXT subsystem.
#if !defined(HAL_USE_EXT) || defined(__DOXYGEN__)
#define HAL_USE_EXT                 TRUE
 * @brief   Enables the GPT subsystem.
#if !defined(HAL_USE_GPT) || defined(__DOXYGEN__)
#define HAL_USE_GPT                 FALSE
 * @brief   Enables the I2C subsystem.
#if !defined(HAL_USE_I2C) || defined(__DOXYGEN__)
#define HAL_USE_I2C                 FALSE
 * @brief   Enables the ICU subsystem.
#if !defined(HAL_USE_ICU) || defined(__DOXYGEN__)
#define HAL_USE_ICU                 FALSE
 * @brief   Enables the MAC subsystem.
#if !defined(HAL_USE_MAC) || defined(__DOXYGEN__)
#define HAL_USE_MAC                 FALSE
 * @brief   Enables the MMC_SPI subsystem.
#if !defined(HAL_USE_MMC_SPI) || defined(__DOXYGEN__)
#define HAL_USE_MMC_SPI             FALSE
 * @brief   Enables the PWM subsystem.
#if !defined(HAL_USE_PWM) || defined(__DOXYGEN__)
#define HAL_USE_PWM                 FALSE
 * @brief   Enables the RTC subsystem.
#if !defined(HAL_USE_RTC) || defined(__DOXYGEN__)
#define HAL_USE_RTC                 FALSE
 * @brief   Enables the SDC subsystem.
#if !defined(HAL_USE_SDC) || defined(__DOXYGEN__)
#define HAL_USE_SDC                 FALSE
 * @brief   Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL              FALSE
 * @brief   Enables the SERIAL over USB subsystem.
#if !defined(HAL_USE_SERIAL_USB) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL_USB          FALSE
 * @brief   Enables the SPI subsystem.
#if !defined(HAL_USE_SPI) || defined(__DOXYGEN__)
#define HAL_USE_SPI                 FALSE
 * @brief   Enables the UART subsystem.
#if !defined(HAL_USE_UART) || defined(__DOXYGEN__)
#define HAL_USE_UART                TRUE
 * @brief   Enables the USB subsystem.
#if !defined(HAL_USE_USB) || defined(__DOXYGEN__)
#define HAL_USE_USB                 FALSE
/* ADC driver related settings.                                              */
 * @brief   Enables synchronous APIs.
 * @note    Disabling this option saves both code and data space.
#if !defined(ADC_USE_WAIT) || defined(__DOXYGEN__)
#define ADC_USE_WAIT                TRUE
 * @brief   Enables the @p adcAcquireBus() and @p adcReleaseBus() APIs.
#if !defined(ADC_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define ADC_USE_MUTUAL_EXCLUSION    TRUE
/* CAN driver related settings.                                              */
 * @brief   Sleep mode related APIs inclusion switch.
#if !defined(CAN_USE_SLEEP_MODE) || defined(__DOXYGEN__)
#define CAN_USE_SLEEP_MODE          TRUE
/* I2C driver related settings.                                              */
 * @brief   Enables the mutual exclusion APIs on the I2C bus.
#if !defined(I2C_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define I2C_USE_MUTUAL_EXCLUSION    TRUE
/* MAC driver related settings.                                              */
 * @brief   Enables an event sources for incoming packets.
#if !defined(MAC_USE_ZERO_COPY) || defined(__DOXYGEN__)
#define MAC_USE_ZERO_COPY           FALSE
#if !defined(MAC_USE_EVENTS) || defined(__DOXYGEN__)
#define MAC_USE_EVENTS              TRUE
/* MMC_SPI driver related settings.                                          */
 * @brief   Delays insertions.
 * @details If enabled this options inserts delays into the MMC waiting
 *          routines releasing some extra CPU time for the threads with
 *          lower priority, this may slow down the driver a bit however.
 *          This option is recommended also if the SPI driver does not
 *          use a DMA channel and heavily loads the CPU.
#if !defined(MMC_NICE_WAITING) || defined(__DOXYGEN__)
#define MMC_NICE_WAITING            TRUE
/* SDC driver related settings.                                              */
 * @brief   Number of initialization attempts before rejecting the card.
 * @note    Attempts are performed at 10mS intervals.
#if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
#define SDC_INIT_RETRY              100
 * @brief   Include support for MMC cards.
 * @note    MMC support is not yet implemented so this option must be kept
 *          at @p FALSE.
#if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
#define SDC_MMC_SUPPORT             FALSE
#if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
#define SDC_NICE_WAITING            TRUE
/* SERIAL driver related settings.                                           */
 * @brief   Default bit rate.
 * @details Configuration parameter, this is the baud rate selected for the
 *          default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE      38400
 * @brief   Serial buffers size.
 * @details Configuration parameter, you can change the depth of the queue
 *          buffers depending on the requirements of your application.
 * @note    The default is 64 bytes for both the transmission and receive
 *          buffers.
#if !defined(SERIAL_BUFFERS_SIZE) || defined(__DOXYGEN__)
#define SERIAL_BUFFERS_SIZE         16
/* SPI driver related settings.                                              */
#if !defined(SPI_USE_WAIT) || defined(__DOXYGEN__)
#define SPI_USE_WAIT                TRUE
 * @brief   Enables the @p spiAcquireBus() and @p spiReleaseBus() APIs.
#if !defined(SPI_USE_MUTUAL_EXCLUSION) || defined(__DOXYGEN__)
#define SPI_USE_MUTUAL_EXCLUSION    TRUE
#endif /* _HALCONF_H_ */
mcuconf.h:
define STM32F30x_MCUCONF
 * HAL driver system settings.
#define STM32_HSI_ENABLED                   TRUE
#define STM32_LSI_ENABLED                   TRUE
#define STM32_PREDIV_VALUE                  1
#define STM32_PLLMUL_VALUE                  9
#define STM32_PPRE1                         STM32_PPRE1_DIV2
#define STM32_PPRE2                         STM32_PPRE2_DIV2
#define STM32_MCOSEL                        STM32_MCOSEL_NOCLOCK
#define STM32_ADC12PRES                     STM32_ADC12PRES_DIV1
#define STM32_ADC34PRES                     STM32_ADC34PRES_DIV1
#define STM32_USART1SW                      STM32_USART1SW_PCLK
#define STM32_USART2SW                      STM32_USART2SW_PCLK
#define STM32_USART3SW                      STM32_USART3SW_PCLK
#define STM32_UART4SW                       STM32_UART4SW_PCLK
#define STM32_UART5SW                       STM32_UART5SW_PCLK
#define STM32_I2C1SW                        STM32_I2C1SW_SYSCLK
#define STM32_I2C2SW                        STM32_I2C2SW_SYSCLK
#define STM32_TIM1SW                        STM32_TIM1SW_PCLK2
#define STM32_TIM8SW                        STM32_TIM8SW_PCLK2
#define STM32_RTCSEL                        STM32_RTCSEL_LSI
#define STM32_USB_CLOCK_REQUIRED            TRUE
#define STM32_USBPRE                        STM32_USBPRE_DIV1P5
 * ADC driver system settings.
#define STM32_ADC_USE_ADC1                  TRUE
#define STM32_ADC_USE_ADC3                  TRUE
#define STM32_ADC_ADC12_DMA_PRIORITY        2
#define STM32_ADC_ADC34_DMA_PRIORITY        2
#define STM32_ADC_ADC12_IRQ_PRIORITY        5
#define STM32_ADC_ADC34_IRQ_PRIORITY        5
#define STM32_ADC_ADC12_DMA_IRQ_PRIORITY    5
#define STM32_ADC_ADC34_DMA_IRQ_PRIORITY    5
#define STM32_ADC_ADC12_CLOCK_MODE          ADC_CCR_CKMODE_AHB_DIV1
#define STM32_ADC_ADC34_CLOCK_MODE          ADC_CCR_CKMODE_AHB_DIV1
#define STM32_ADC_DUAL_MODE                 TRUE
 * CAN driver system settings.
#define STM32_CAN_USE_CAN1                  FALSE
#define STM32_CAN_CAN1_IRQ_PRIORITY         11
 * EXT driver system settings.
#define STM32_EXT_EXTI0_IRQ_PRIORITY        6
#define STM32_EXT_EXTI1_IRQ_PRIORITY        6
#define STM32_EXT_EXTI2_IRQ_PRIORITY        6
#define STM32_EXT_EXTI3_IRQ_PRIORITY        6
#define STM32_EXT_EXTI4_IRQ_PRIORITY        6
#define STM32_EXT_EXTI5_9_IRQ_PRIORITY      6
#define STM32_EXT_EXTI10_15_IRQ_PRIORITY    6
#define STM32_EXT_EXTI16_IRQ_PRIORITY       6
#define STM32_EXT_EXTI17_IRQ_PRIORITY       6
#define STM32_EXT_EXTI18_IRQ_PRIORITY       6
#define STM32_EXT_EXTI19_IRQ_PRIORITY       6
#define STM32_EXT_EXTI20_IRQ_PRIORITY       6
#define STM32_EXT_EXTI21_22_29_IRQ_PRIORITY 6
#define STM32_EXT_EXTI30_32_IRQ_PRIORITY    6
#define STM32_EXT_EXTI33_IRQ_PRIORITY       6
 * GPT driver system settings.
#define STM32_GPT_USE_TIM1                  FALSE
#define STM32_GPT_USE_TIM2                  FALSE
#define STM32_GPT_USE_TIM3                  FALSE
#define STM32_GPT_USE_TIM4                  FALSE
#define STM32_GPT_USE_TIM6                  FALSE
#define STM32_GPT_USE_TIM7                  FALSE
#define STM32_GPT_USE_TIM8                  FALSE
#define STM32_GPT_TIM1_IRQ_PRIORITY         7
#define STM32_GPT_TIM2_IRQ_PRIORITY         7
#define STM32_GPT_TIM3_IRQ_PRIORITY         7
#define STM32_GPT_TIM4_IRQ_PRIORITY         7
#define STM32_GPT_TIM6_IRQ_PRIORITY         7
#define STM32_GPT_TIM7_IRQ_PRIORITY         7
#define STM32_GPT_TIM8_IRQ_PRIORITY         7
 * I2C driver system settings.
#define STM32_I2C_USE_I2C1                  FALSE
#define STM32_I2C_USE_I2C2                  FALSE
#define STM32_I2C_I2C1_IRQ_PRIORITY         10
#define STM32_I2C_I2C2_IRQ_PRIORITY         10
#define STM32_I2C_I2C1_DMA_PRIORITY         1
#define STM32_I2C_I2C2_DMA_PRIORITY         1
#define STM32_I2C_DMA_ERROR_HOOK(i2cp)      chSysHalt()
 * ICU driver system settings.
#define STM32_ICU_USE_TIM1                  FALSE
#define STM32_ICU_USE_TIM2                  FALSE
#define STM32_ICU_USE_TIM3                  FALSE
#define STM32_ICU_USE_TIM4                  FALSE
#define STM32_ICU_USE_TIM8                  FALSE
#define STM32_ICU_TIM1_IRQ_PRIORITY         7
#define STM32_ICU_TIM2_IRQ_PRIORITY         7
#define STM32_ICU_TIM3_IRQ_PRIORITY         7
#define STM32_ICU_TIM4_IRQ_PRIORITY         7
#define STM32_ICU_TIM8_IRQ_PRIORITY         7
 * PWM driver system settings.
#define STM32_PWM_USE_ADVANCED              FALSE
#define STM32_PWM_USE_TIM1                  FALSE
#define STM32_PWM_USE_TIM2                  FALSE
#define STM32_PWM_USE_TIM3                  FALSE
#define STM32_PWM_USE_TIM4                  FALSE
#define STM32_PWM_USE_TIM8                  FALSE
#define STM32_PWM_TIM1_IRQ_PRIORITY         7
#define STM32_PWM_TIM2_IRQ_PRIORITY         7
#define STM32_PWM_TIM3_IRQ_PRIORITY         7
#define STM32_PWM_TIM4_IRQ_PRIORITY         7
#define STM32_PWM_TIM8_IRQ_PRIORITY         7
#define STM32_SERIAL_USE_USART1             FALSE
#define STM32_SERIAL_USE_USART2             FALSE
#define STM32_SERIAL_USE_USART3             FALSE
#define STM32_SERIAL_USE_UART4              FALSE
#define STM32_SERIAL_USE_UART5              FALSE
#define STM32_SERIAL_USART1_PRIORITY        12
#define STM32_SERIAL_USART2_PRIORITY        12
#define STM32_SERIAL_USART3_PRIORITY        12
#define STM32_SERIAL_UART4_PRIORITY         12
#define STM32_SERIAL_UART5_PRIORITY         12
 * SPI driver system settings.
#define STM32_SPI_USE_SPI1                  FALSE
#define STM32_SPI_USE_SPI2                  FALSE
#define STM32_SPI_USE_SPI3                  FALSE
#define STM32_SPI_SPI1_DMA_PRIORITY         1
#define STM32_SPI_SPI2_DMA_PRIORITY         1
#define STM32_SPI_SPI3_DMA_PRIORITY         1
#define STM32_SPI_SPI1_IRQ_PRIORITY         10
#define STM32_SPI_SPI2_IRQ_PRIORITY         10
#define STM32_SPI_SPI3_IRQ_PRIORITY         10
#define STM32_SPI_DMA_ERROR_HOOK(spip)      chSysHalt()
 * UART driver system settings.
#define STM32_UART_USE_USART1               TRUE
#define STM32_UART_USE_USART2               TRUE
#define STM32_UART_USE_USART3               TRUE
#define STM32_UART_USART1_IRQ_PRIORITY      12
#define STM32_UART_USART2_IRQ_PRIORITY      12
#define STM32_UART_USART3_IRQ_PRIORITY      12
#define STM32_UART_USART1_DMA_PRIORITY      0
#define STM32_UART_USART2_DMA_PRIORITY      0
#define STM32_UART_USART3_DMA_PRIORITY      0
#define STM32_UART_DMA_ERROR_HOOK(uartp)    chSysHalt()
 * USB driver system settings.
#define STM32_USB_USE_USB1                  FALSE
#define STM32_USB_LOW_POWER_ON_SUSPEND      FALSE
#define STM32_USB_USB1_HP_IRQ_PRIORITY      13
#define STM32_USB_USB1_LP_IRQ_PRIORITY      14
Re: ADC-UART Problem
Have you enabled the debug options in chconf.h? assertions or the state checker may discover what is happening. You need the inspect the string pointed by the global pointer variable dbg_panic_msg after the program stopped using the debugger.
About ADCs, the F3 driver only support ADC1 and ADC3 in "single" mode or the couples ADC1+ADC2 and ADC3+ADC4 in "coupled" mode. Single mode for ADC2 and ADC4 is not supported.
fischer
Post by fischer »
Thank you for the fast answer. How complicate is it to write a driver to use ADC2 and ADC4 in single mode?
Very complex and not really needed in most cases, why you have to use them? is there something ADC1 or ADC3 cannot do?
fischer
Post by fischer »
No my problem is that i need 22 adc channels
You could try the dual mode, if just have to sample at least one channel per ADC unit.
