MMC Over SPI Troubles With Embest Board
abbyj
Post by abbyj »
Hi Gents,
I've tried compiling the demo for the STM32F4 and have updated my board files (Thank you Tectu for your help with the board files!), but I am still not able to access the SD card. :oops: I have tried a SanDisk 4GB and a Crucial 1GB.
Where else should I be looking to find my problem? Is there a setting that needs to be TRUE/FALSE in order for it to work? It appears that the InsertHandler/RemoveHandler is not running. Is there a particular frequency that needs to be set for it to work?
Thank you very much in advance for your help!
Jason
Re: MMC Over SPI Troubles With Embest Board
In order to make those handlers work, you must provide the card detect code for your board in board.c.
resset
Post by resset »
On Embest board there is a GPIOB_PIN15 that is connected to ~CD of the card, so it should work as a card detect, only negated. It is not configured in Tectu's board files, however. Should be sth like this: GPIOB_SD_DETECT.
Can you please upload a .zip of your code containing your board files? There are different versions of Tectu's board files out there. I will try to get a final one together this weekend.
resset
Post by resset »
Tectu wrote:Can you please upload a .zip of your code containing your board files? There are different versions of Tectu's board files out there. I will try to get a final one together this weekend.
If you asked about mine, I attach them below. :-)
EMBEST_DMSTF4BB.zip
(9.89 KiB) Downloaded 513 times
