Need help porting code from IAR to Eclipse
dhruvin91
Post by dhruvin91 »
We used IAR to work on our project. But now we are looking for better debug functionality and thus moving to chibistudio. But We are having problems with preprocessor include.
To be specific, We are using GFX library. I added the location to paths and symbols and it shows up in preprocessor includes. But while building proj, it complains that gfx.h is not found.
Can some one help us out with this?
Thank you.
Re: Need help porting code from IAR to Eclipse
Applications in ChibiStudio use makefiles, if you start from an existing application you just need to customize the makefile. Remove the files you don't need and add your own.
If you plan to use a CDT project (it build makefiles automatically) I can't be of much help, I never used it. You should try some Eclipse CDT mailing list.
dhruvin91
Post by dhruvin91 »
It was prblem with makefile.
Thank you for the help.
Dhruvin
