usb_serial stops working after reset
part1zan_
Post by part1zan_ »
What I do is a small demo app to play with on an STM32F3Discovery board. It utilizes the ChibiOS console. What is wrong is that when I reset the device (to check something, for instance), I cannot connect to the USB console. The device (/dev/ttyACM0) appears in the system, but unfortunately is inaccessible. The code that invokes the shell looks like the code below:
#include "ch.h"
#include "test.h"
#include "spi.h"
#include "i2c.h"
#include "usbcfg.h"
#include "chprintf.h"
#include "shell.h"
#include "chthreads.h"
// testing rtc
#include "rtc.h"
#include "chrtclib.h"
#define usb_lld_connect_bus(usbp)
#define usb_lld_disconnect_bus(usbp)
/* Virtual serial port over USB.*/
SerialUSBDriver SDU1;
blah, blah, blah, some functions
#define SHELL_WA_SIZE   THD_WA_SIZE(1024)
blah, blah, blah, funcitons with shell commands
static const ShellCommand shCmds[] = {
  {"test",      cmd_test},
  {"helpme",   cmd_help},
  {"gyrodata",   cmd_gyrodata},
  {"magdata", cmd_magdata},
  {"adjust", cmd_adjust},
  {"nextsch", cmd_nextsch},
  {"time", cmd_time},
  {"free", cmd_mem},
  {"reboot", cmd_reboot},
  {NULL, NULL}
static const ShellConfig shCfg = {
  (BaseSequentialStream *)&SDU1,
  shCmds
blah, blah, blah, some other irrelevant code
int main(void) {
   Thread *sh = NULL;
   sduObjectInit(&SDU1);
   sduStart(&SDU1, &serusbcfg);
    chThdSleepMilliseconds(1000);
    spiStart(&SPID1, &spi1cfg);
    i2cStart(&I2CD1, &i2cconfig);
    initGyro();
    initAccel();
    initMag();
   shellInit();
   chThdCreateStatic(waThreadBlink, sizeof(waThreadBlink), NORMALPRIO, ThreadBlink, NULL);
    while (TRUE) {
      if (!sh) {
         sh = shellCreate(&shCfg, SHELL_WA_SIZE, NORMALPRIO);
      else if (chThdTerminated(sh)) {
         chThdRelease(sh);
         sh = NULL;
   return 0; // never returns, lol
Somewhy, I am pretty sure that the bug is in my code. Please tell me where it might be. Also, this is unlikely to be an STM32-specific issue.
Re: usb_serial stops working after reset
What exactly do you mean by inaccessible? Probably you really just have a permissions problem on your machine. I didn't check your code but if the device shows up, you should be able to build up a connection to it. Does the LED keep blinking?
part1zan_
Post by part1zan_ »
Yes, the LED keeps blinking, the device's permissions are ok:
$ ls -l /dev/ttyA*
crw-rw---- 1 root dialout 166, 0 окт.  17 22:39 /dev/ttyACM0
part1zan_
Post by part1zan_ »
Tried using screen for connecting to the device, and screen said:
Cannot open line '/dev/ttyACM0' for R/W: Input/output error
And then:
Sorry, could not find a PTY.
Did you actually use root access to talk to the device? otherwise make sure that your user is in the allowed groups.
Personally, I use minicom with which I never had any issues at all.
part1zan_
Post by part1zan_ »
I tried root user, my user is in dialout group (which has rw permissions for the device -- see above). I also mostly use minicom, because it's reliable and really convenient
part1zan_
Post by part1zan_ »
Let me paraphrase my question a little bit. My main subroutine (which I somewhy find the buggiest place in the code listed above) looks like this:
int main(void) {
   Thread *sh = NULL;
    initGyro();
    initAccel();
    initMag();
   shellInit();
//   palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7));
//   palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7));
    while (TRUE) {
      if (!sh) {
         chThdRelease(sh);
         sh = NULL;
Can the above code cause disconnections and shell malfunctions after reboot? Could I forget to state something above the main subroutine?
You should first start the USB then SDU, please follow the examples.
part1zan_
Post by part1zan_ »
Sorry to say that, but starting SDU before USB didn't help. Could you tell me which exact examples (with links) I should look at?
Could this be a hardware problem?
The STM32F3-Discovery is unable to control the USB pull-up resistor that allows to detect the device, it is always ON. After restarting an application or resetting the board is mandatory to disconnect the USB cable and connect it again or the host cannot detect the board again.
This is a problem specific to this board only.
