STM32 Memory Model using ChibiOS
sachin maganti
Post by sachin maganti »
HI,
I wanted to know as to how to find the Memory model / memory layout of STM32F407 ARM cortex M4 board which has a 1Mb Flash and 192k SRAM, kindly let me know as to how to find the size of Program memory ( Data segment), Text segment , size of Stack and Heap using ChibiOs, i am running my code in GCC compiler
Thanks & Regards,
Sachin maganti
Re: STM32 Memory Model using ChibiOS
If you look at the generated build/ch.map and build/ch.dmp files you can get all the info about the compiled application.
