[DONE] Win32-MinGW demo
DeusExMachina
Has thanked: 3 times
Post by DeusExMachina »
I tried to work with windows simulator: first I used 2.6.1 version and had succesfully compiled ch.exe by mingw32 toolchain. But I can't see application output via putty, only blanc screen. Connection to both ports was sucessfull.
I tried to use 2.6.2 version, but demo compilation fails (unresolved msObjectInit in chprintf.c).
I inserted code after 75 line of makefile
       ${CHIBIOS}/os/various/memstreams.c \
and was able to compile app. But the terminal issue remains. Also on closing putty ch.exe crashes.
How can I fix the problem?
DeusExMachina
Re: Win32-MinGW demo
gcc version is 4.8.1
DeusExMachina
It seems that connect events (SD1 or SD2) never take place. I used debugger, system waits infinitelly
   * Events servicing loop.
  while (!chThdShouldTerminate());
    chEvtDispatch(fhandlers, chEvtWaitOne(ALL_EVENTS));
I will verify it.
Re: [TODO] Win32-MinGW demo
I fixed the makefiles but I cannot reproduce the other problem using my older MinGW, it is possible it is a stack overflow issue.
DeusExMachina
Re: [DONE] Win32-MinGW demo
Giovanni, what MinGW version you use? May be it is my Windows-related issue
It is an old 3.2.4 or something like that.
DeusExMachina
I tried to compile the demo on another pc. Everything was OK, demo worked. I think it is my windows problem.
DeusExMachina
Also, what does this define mean?
 * @brief   Port-specific information string.
#define CH_PORT_INFO                    "No preemption"
This port is cooperative-like OS?
Yes, the simulators are cooperative only, I've found no easy way to preempt a win32 process.
