HC-05 serial bluetooth module support
Posted: Sun Jan 19, 2014 4:40 pm
I wrote code to use the HC-05 serial bluetooth module in ChibiOS projects.
The code is at http://code.google.com/p/chibios-bluetooth/
This is my first ever real-life code contribution and I would like to ask for your comments on it.
Most of the bluetooth-related commands are macros, as we have to send the modul AT commands in AT mode, but in communication mode, it is only a serial port.
For some reason I could not track down, only the first AT command is interpreted by the module (e.g. setting the name), but the others (setting the pin) are not.
A workaround is to reset the module after each at command, but it is not that efficient.
I started to create some documentation, so that the code could be easier to follow. For some reason doxygen simply ignores it.
Do you have any ideas?
Thank you,
Peter
Thank you,
Peter
