Devkit407
Posted: Wed Mar 05, 2014 10:51 am
by jarekl
I'm trying to use the embest board (STM32F4DIS-BB) with the SMT32F4-discovery kit. Though it is mentioned in the forums, I can't find anything concrete.
So, my question it, what do I need to do to make it work. Do I need to create new board files (board.h/board.c)? Any pointers would be greatly appreciated.
Re: Devkit407
Posted: Wed Mar 05, 2014 11:08 am
I think board files have been posted in the forum. If I remember well the problem is that you cannot have all accessories together because conflicts, you need custom board files depending on what you attach.
Re: Devkit407
Posted: Thu Mar 06, 2014 4:29 pm
by jarekl
Yes, I found one and eventually I got it to compile. There was some confusion with the CMSIS api (which header file should be included where).
I used the board file from this demo: viewtopic.php?f=14&t=1589&p=14728&hilit=fatfs+embest#p13710
However, the demo didn't work in so far that the USB-CDC interface did not appear on my PC (I have coded and used the USB-serial stuff before so
I think I know how to do that).
I did use the board definition provided in that demo to see if I could make it work in my application but it simply seems to kill USB
altogether (not only the serial stuff).
If I use the board files in boards/ST_STM32F4_DISCOVERY, USB works but I cannot access the SD Card.
My question is really, what do I need to read and understand to get this to work. Chibi has been fairly straight forward until now
but maybe I have to dig deeper. I plan to eventually build a custom board based on the 427-cpu with another pinout and some
other hardware coupled to it so probably this is something I need to know anyway.
Re: Devkit407
Posted: Thu Mar 06, 2014 5:18 pm
You have to verify if there are conflicts on the USB pins, that baseboard does have such problems. USB is well known to work on the normal F4 Discovery.
Re: Devkit407
Posted: Sun Mar 09, 2014 4:47 pm
by jarekl
Giovanni wrote:Hi,
Yes, it works on mine with the stm32f4 board files too, even with the embest board mounted. It stops working when I use a different board file. That's why I wonder how do I debug board files. What do they do for chibhi and where can I learn about it?
Re: Devkit407
Posted: Sun Mar 09, 2014 8:29 pm
You have to study the schematic of those boards and compare with board files definitions, while doing that look also for possible conflicts.
