/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS 5
/* Depth of the conversion buffer, channels are sampled five times each.*/
#define ADC_GRP1_BUF_DEPTH 2
/* This is the scaling factor to convert to voltages.*/
#define ADC_SCALING_V44 (0.000732 * 2)
#define ADC_SCALING_V30 (0.000732 * 2)
#define ADC_SCALING_VBAT (0.000732 * 2)
#define ADC_SCALING_VIN (0.000732 * 10)
* ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
* ADC conversion group.
* Mode: Linear buffer, 4 samples of 2 channels, SW triggered.
* Channels: IN11 (48 cycles sample time)
* Sensor (192 cycles sample time)
static const ADCConversionGroup adcgrpcfg = {
FALSE,
ADC_GRP1_NUM_CHANNELS,
adccb,
NULL,
/* HW dependent part.*/
0,
ADC_CR2_SWSTART,
ADC_SMPR2_SMP_AN1(ADC_SAMPLE_480) |
ADC_SMPR2_SMP_AN2(ADC_SAMPLE_480) |
ADC_SMPR2_SMP_AN3(ADC_SAMPLE_480) |
ADC_SMPR1_SMP_VBAT(ADC_SAMPLE_480) |
ADC_SMPR1_SMP_SENSOR(ADC_SAMPLE_480),
0,
ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
0,
ADC_SQR3_SQ1_N(ADC_CHANNEL_IN1) |
ADC_SQR3_SQ2_N(ADC_CHANNEL_IN2) |
ADC_SQR3_SQ3_N(ADC_CHANNEL_IN3) |
ADC_SQR3_SQ4_N(ADC_CHANNEL_VBAT) |
ADC_SQR3_SQ5_N(ADC_CHANNEL_SENSOR)
* ADC end conversion callback.
void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
(void) n;
(void)buffer;
/* Note, only in the ADC_COMPLETE state because the ADC driver fires an
intermediate callback when the buffer is half full.*/
if (adcp->state == ADC_COMPLETE)
float ch1, ch2, ch3, ch4, ch5;
palTogglePad(GPIOG, GPIOG_LED_STATUS_GRN);
/* Calculates the average values from the ADC samples.*/
ch1 = ((samples[0] + samples[5]) / ADC_GRP1_BUF_DEPTH) * ADC_SCALING_VIN;
ch2 = ((samples[1] + samples[6]) / ADC_GRP1_BUF_DEPTH) * ADC_SCALING_V30;
ch3 = ((samples[2] + samples[7]) / ADC_GRP1_BUF_DEPTH) * ADC_SCALING_V44;
ch4 = ((samples[3] + samples[8]) / ADC_GRP1_BUF_DEPTH) * ADC_SCALING_VBAT;
ch5 = ((samples[4] + samples[9]) / ADC_GRP1_BUF_DEPTH);
ch5 = ((ch5 - 760) / 2.5) + 25;
chSysLockFromIsr();
adcStartConversionI(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
chSysUnlockFromIsr();
void psuInit(void)
* Initializes the ADC driver 1 and enable the thermal sensor.
* The pin PC1 on the port GPIOC is programmed as analog input.
adcSTM32EnableVBATE();
adcSTM32EnableTSVREFE();
adcStart(&ADCD1, NULL);
adcStartConversion(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
Is this correct as the temp is coming out all wrong, temp is on ch5 ?
