[DONE] STM3241G-EVAL Ethernet
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
Trying to get ethernet working on my STM3241G-EVAL, the Phy on the board is DP83848. Got the board configure to run with Ext 25Mhz for the Phy, and have set the Board config to the correct BOARD_PHY_ID, and commented out #define BOARD_PHY_RMII as i want to run MII interface.
 * Ethernet PHY type.
#define BOARD_PHY_ID            MII_DP83848I_ID
//#define BOARD_PHY_RMII
At the moment the code loops here
  /* MAC clocks activation and commanded reset procedure.*/
  rccEnableETH(FALSE);
  ETH->DMABMR |= ETH_DMABMR_SR;
  while(ETH->DMABMR & ETH_DMABMR_SR)
Ive attached the board file, as i think its right but sometimes a new pair of eyes can see faults
board.zip
(8.95 KiB) Downloaded 352 times
Re: STM3241G-EVAL Ethernet
It is most likely an error in the board files, that board is very complex, you have to verify each pin vs the schematic.
Tabulous
Post by Tabulous »
Giovanni wrote:It is most likely an error in the board files, that board is very complex, you have to verify each pin vs the schematic.
I've been over it so many times, i'm convince i'm missing something.
The mac_lld_init() works ok its when the macStart() is called where it loops
Tabulous
Post by Tabulous »
if I comment out the reset and while loop, everything runs ok and i can hit the web server demo with my browser
//  ETH->DMABMR |= ETH_DMABMR_SR;
//  while(ETH->DMABMR & ETH_DMABMR_SR)
So i guess the question is why does this loop for ? and what is it actually doing ?
Tabulous
Post by Tabulous »
Hi Giovanni
i believe there is a bug here.
You are calling to reset the MAC, but it is not in power up state, as you dont call power up until after, hence it just loops for ever.
  while(ETH->DMABMR & ETH_DMABMR_SR);
what i think you should have, and it works on my STM3241G-EVAL is
#if STM32_MAC_ETH1_CHANGE_PHY_STATE
  /* PHY in power up mode.*/
  mii_write(macp, MII_BMCR, mii_read(macp, MII_BMCR) & ~BMCR_PDOWN);
Instead of doing that, could you try to put a delay after "rccEnableETH(FALSE);", you may use halPolledDelay();
Tabulous
Post by Tabulous »
Giovanni wrote:Hi,
  halPolledDelay(1000);
having a delay has no effect, still loops in while loop.
Tabulous
Post by Tabulous »
Tabulous wrote:
Giovanni wrote:Hi,
As above having a delay has no effect, still loops in while loop.
I decided to remove the reset operation and the loop entirely, see if this works for you.
Tabulous
Post by Tabulous »
Giovanni wrote:I decided to remove the reset operation and the loop entirely, see if this works for you.
i can confirm removing this, causes no issues on my board, Ethernet is still running good :-)
