I am trying to get data from gps and read it using STM32F4 mcu. I am using serial driver which reads bytes sent by gps and parse these bytes to get meaningful data. I am using sdRead() function to read data from serial buffer. I am using this function without any delay in tread so I assume I am updating function as fast as I can. However I am not able to get checksum properly as it fails everytime. Also data is not consistent as if I am loosing few bytes. I suspected this might be problem of buffer but then I increase size of buffer to 512 still having same problem.
I have check my parsing code on arduino and it works perfectly fine.
I am thinking of using uart driver but I suppose it does not have buffer implementation. Is there any solution to this problem. What is the difference when I call sdRead, sdAsychromousRead(), sdGet()?
Serial Driver Problem
Re: Serial Driver Problem
What version are you using? a bug has been recently fixed in the serial driver, update to 2.6.3.
daniellpu9
Hi to everyone,
i have this code
I think that i have the mcuconf.h and hal.h well configurated. What i have wrong????... Plz help me!!!!!!!!!!!!!!
i have this code
#include "ch.h"
#include "test.h"
static void pwmpcb(PWMDriver *pwmp);
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n);
static void spicb(SPIDriver *spip);
int avg_ch1, avg_ch2;
int bla= 0x0400;
int dat1,dat2;
/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS 1
/* Depth of the conversion buffer, channels are sampled four times each.*/
#define ADC_GRP1_BUF_DEPTH 4
* ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
* ADC conversion group.
* Mode: Linear buffer, 4 samples of 2 channels, SW triggered.
* Channels: IN11 (48 cycles sample time)
* Sensor (192 cycles sample time)
static const ADCConversionGroup adcgrpcfg = {
FALSE,
ADC_GRP1_NUM_CHANNELS,
adccb,
NULL,
/* HW dependent part.*/
ADC_CR1_RES_1,
ADC_CR2_SWSTART,
ADC_SMPR1_SMP_AN11(ADC_SAMPLE_56),
0,
ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
0,
ADC_SQR3_SQ1_N(ADC_CHANNEL_IN11)
* SPI configuration structure.
* Maximum speed (12MHz), CPHA=1, CPOL=1, 16bits frames, MSb transmitted first.
* The slave select line is the pin GPIOA_SPI1NSS on the port GPIOA.
static const SPIConfig spicfg = {
spicb,
GPIOB,
12,
SPI_CR1_DFF | SPI_CR1_CPHA | SPI_CR1_CPOL | SPI_CR1_BR_2 | SPI_CR1_BR_0
//SPI_CR1_CPHA | SPI_CR1_CPOL |SPI_CR1_BR_2
* ADC end conversion callback.
* The PWM channels are reprogrammed using the latest ADC samples.
* The latest samples are transmitted into a single SPI transaction.
void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
(void) buffer; (void) n;
/* Note, only in the ADC_COMPLETE state because the ADC driver fires an
intermediate callback when the buffer is half full.*/
if (adcp->state == ADC_COMPLETE) {
/* Calculates the average values from the ADC samples.*/
avg_ch1 = (samples[0] + samples[1] + samples[2] + samples[3]) / 4;
* SPI end transfer callback.
static void spicb(SPIDriver *spip) {
/* On transfer end just releases the slave select line.*/
chSysLockFromIsr();
spiUnselectI(spip);
chSysUnlockFromIsr();
* This is a periodic thread that does absolutely nothing except flashing
* a LED.
static WORKING_AREA(waThread1, 128);
(void)arg;
chRegSetThreadName("ADC");
while (TRUE) {
palSetPad(GPIOD, GPIOD_LED3); /* Orange. */
chThdSleepMilliseconds(20);
chSysLockFromIsr();
adcStartConversionI(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
palClearPad(GPIOD, GPIOD_LED3); /* Orange. */
static WORKING_AREA(waThread2, 128);
static msg_t Thread2(void *arg) {
(void)arg;
chRegSetThreadName("SPI");
while (TRUE) {
palSetPad(GPIOD, GPIOD_LED4); // Green.
chSysLockFromIsr();
// SPI slave selection and transmission start.
spiSelectI(&SPID2);
spiStartSendI(&SPID2, 1, &bla);
chThdSleepMilliseconds(1);
spiStartReceiveI(&SPID2, 1, &avg_ch2);
dat1 = avg_ch2 & 0xFF;
dat2 = (avg_ch2 & 0xFF00) >>8;
palClearPad(GPIOD, GPIOD_LED4); // Green.
static WORKING_AREA(waThread3, 128);
static msg_t Thread3(void *arg) {
(void)arg;
chRegSetThreadName("GPS");
while (TRUE) {
chSysLockFromIsr();
palSetPad(GPIOD, GPIOD_LED5); // Red.
chThdSleepMilliseconds(2000);
palClearPad(GPIOD, GPIOD_LED5); // Red .
* Application entry point.
int main(void) {
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
* PA9(TX) and PA10(RX) are routed to USART1.
sdStart(&SD1, NULL);
palSetPadMode(GPIOA, 9, PAL_MODE_ALTERNATE(7));
palSetPadMode(GPIOA, 10, PAL_MODE_ALTERNATE(7));
* Activates the serial driver 2 using the driver default configuration.
* PA2(TX) and PA3(RX) are routed to USART2.
sdStart(&SD2, NULL);
palSetPadMode(GPIOA, 2, PAL_MODE_ALTERNATE(7));
palSetPadMode(GPIOA, 3, PAL_MODE_ALTERNATE(7));
* Initializes the SPI driver 2. The SPI2 signals are routed as follow:
* PB12 - NSS.
* PB13 - SCK.
* PB14 - MISO.
* PB15 - MOSI.
spiStart(&SPID2, &spicfg);
palSetPad(GPIOB, 12);
palSetPadMode(GPIOB, 12, PAL_MODE_OUTPUT_PUSHPULL |
PAL_STM32_OSPEED_HIGHEST); /* NSS. */
palSetPadMode(GPIOB, 13, PAL_MODE_ALTERNATE(5) |
PAL_STM32_OSPEED_HIGHEST); /* SCK. */
palSetPadMode(GPIOB, 14, PAL_MODE_ALTERNATE(5)); /* MISO. */
palSetPadMode(GPIOB, 15, PAL_MODE_ALTERNATE(5) |
PAL_STM32_OSPEED_HIGHEST); /* MOSI. */
* Initializes the ADC driver 1 and enable the thermal sensor.
* The pin PC0 on the port GPIOC is programmed as analog input.
adcStart(&ADCD1, NULL);
palSetPadMode(GPIOC, 1, PAL_MODE_INPUT_ANALOG);
* Creates the example thread.
chThdCreateStatic(waThread2, sizeof(waThread2), NORMALPRIO, Thread2, NULL);
chThdCreateStatic(waThread3, sizeof(waThread3), NORMALPRIO, Thread3, NULL);
while (TRUE)
//sdPut(&SD2, avg_ch1);
//sdPut(&SD2, dat1);
//sdPut(&SD2, dat2);
chnWrite(&SD1,(const uint8_t *)"Bla\r\n", 14);
chnWrite(&SD2,(const uint8_t *)"Bla\r\n", 14);
chThdSleepMilliseconds(1000);
}I think that i have the mcuconf.h and hal.h well configurated. What i have wrong????... Plz help me!!!!!!!!!!!!!!
There are several errors, for example:
- FromIsr() functions not into an ISR.
- An "I" function not within lock/unlock.
I recommend reading the "kernel concepts" section in the documentation. You should also activate the state checker in chconf.h, it is able to detect this kind of errors.
daniellpu9
But i use that function FROMISR() because in the STM32F4 example you uses that a lot... i read the documentation about that function and i dont understood >/
