Need help with linking problem
pauper180
Post by pauper180 »
I am using ChibiOS v2.6.3 on an STM32F407, I have no issues with standalone chibiOS, but I am trying to incorporate BACnet Stack from sourceforge version 0.8.0. I am using GCC 4.7 2013q1.
I have all the files compiling but when I get to the linking process it terminates with this error:
arm-none-eabi-gcc build/obj/crt0.o build/obj/vectors.o build/obj/chcore.o build/obj/chcore_v7m.o build/obj/nvic.o build/obj/chsys.o build/obj/chdebug.o build/obj/chlists.o build/obj/chvt.o build/obj/chschd.o build/obj/chthreads.o build/obj/chdynamic.o build/obj/chregistry.o build/obj/chsem.o build/obj/chmtx.o build/obj/chcond.o build/obj/chevents.o build/obj/chmsg.o build/obj/chmboxes.o build/obj/chqueues.o build/obj/chmemcore.o build/obj/chheap.o build/obj/chmempools.o build/obj/hal.o build/obj/adc.o build/obj/can.o build/obj/ext.o build/obj/gpt.o build/obj/i2c.o build/obj/icu.o build/obj/mac.o build/obj/mmc_spi.o build/obj/mmcsd.o build/obj/pal.o build/obj/pwm.o build/obj/rtc.o build/obj/sdc.o build/obj/serial.o build/obj/serial_usb.o build/obj/spi.o build/obj/tm.o build/obj/uart.o build/obj/usb.o build/obj/stm32_dma.o build/obj/hal_lld.o build/obj/adc_lld.o build/obj/ext_lld_isr.o build/obj/can_lld.o build/obj/ext_lld.o build/obj/mac_lld.o build/obj/sdc_lld.o build/obj/pal_lld.o build/obj/i2c_lld.o build/obj/usb_lld.o build/obj/rtc_lld.o build/obj/spi_lld.o build/obj/serial_lld.o build/obj/uart_lld.o build/obj/board.o build/obj/ssd1963.o build/obj/charLCD.o build/obj/pic_io.o build/obj/chprintf.o build/obj/syscalls.o build/obj/apdu.o build/obj/npdu.o build/obj/bacdcode.o build/obj/bacint.o build/obj/bacreal.o build/obj/bacstr.o build/obj/bacapp.o build/obj/bacprop.o build/obj/bactext.o build/obj/datetime.o build/obj/indtext.o build/obj/key.o build/obj/keylist.o build/obj/proplist.o build/obj/debug.o build/obj/bigend.o build/obj/arf.o build/obj/awf.o build/obj/cov.o build/obj/dcc.o build/obj/iam.o build/obj/ihave.o build/obj/rd.o build/obj/rp.o build/obj/rpm.o build/obj/timesync.o build/obj/whohas.o build/obj/whois.o build/obj/wp.o build/obj/wpm.o build/obj/abort.o build/obj/reject.o build/obj/bacerror.o build/obj/ptransfer.o build/obj/memcopy.o build/obj/filename.o build/obj/tsm.o build/obj/bacaddr.o build/obj/address.o build/obj/bacdevobjpropref.o build/obj/bacpropstates.o build/obj/alarm_ack.o build/obj/event.o build/obj/getevent.o build/obj/get_alarm_sum.o build/obj/readrange.o build/obj/timestamp.o build/obj/version.o build/obj/device.o build/obj/rs485.o build/obj/dlmstp.o build/obj/timer.o build/obj/automac.o build/obj/ringbuf.o build/obj/fifo.o build/obj/mstp.o build/obj/mstptext.o build/obj/crc.o build/obj/dlenv.o build/obj/txbuf.o build/obj/noserv.o build/obj/h_npdu.o build/obj/h_whois.o build/obj/h_iam.o build/obj/h_rp.o build/obj/h_rp_a.o build/obj/h_rpm.o build/obj/h_rpm_a.o build/obj/h_rr.o build/obj/h_wp.o build/obj/h_wpm.o build/obj/h_alarm_ack.o build/obj/h_arf.o build/obj/h_arf_a.o build/obj/h_awf.o build/obj/h_rd.o build/obj/h_dcc.o build/obj/h_ts.o build/obj/h_whohas.o build/obj/h_ihave.o build/obj/h_cov.o build/obj/h_ccov.o build/obj/h_ucov.o build/obj/h_getevent.o build/obj/h_gas_a.o build/obj/h_get_alarm_sum.o build/obj/h_pt.o build/obj/h_pt_a.o build/obj/h_upt.o build/obj/s_arfs.o build/obj/s_awfs.o build/obj/s_dcc.o build/obj/s_ihave.o build/obj/s_iam.o build/obj/s_cov.o build/obj/s_ptransfer.o build/obj/s_rd.o build/obj/s_router.o build/obj/s_rp.o build/obj/s_rpm.o build/obj/s_ts.o build/obj/s_cevent.o build/obj/s_uevent.o build/obj/s_whohas.o build/obj/s_whois.o build/obj/s_upt.o build/obj/s_wp.o build/obj/main.o -mcpu=cortex-m4 -nostartfiles -T../../chibios/os/ports/GCC/ARMCMx/STM32F4xx/ld/STM32F407xG.ld -Wl,-Map=build/ch.map,--cref,--no-warn-mismatch,--gc-sections -mno-thumb-interwork -mthumb -o build/ch.elf
c:/chibistudio/tools/gnu tools arm embedded/4.7 2013q1/bin/../lib/gcc/arm-none-eabi/4.7.3/../../../../arm-none-eabi/lib/armv7e-m\libc.a(lib_a-fini.o): In function `__libc_fini_array':
fini.c:(.text.__libc_fini_array+0x42): undefined reference to `_fini'
make: *** [build/ch.elf] Error 1
Any help would be much appreciated.
Wilson
Re: Need help with linking problem
That symbol _fini is not exported by the ChibiOS linker script nor from the GCC linker scripts apparently.
You should try to understand which function depends on it. Is something like on_exit() or atexit() used in that library?
colin
Post by colin »
Giovanni is on the right track, _fini is related to dynamic linking, something that you are of course not trying to do. Possibly there is a call to exit() the source code somewhere. You probably need to replace that with something else like a "halt" for such a bare-metal platform.
pauper180
Post by pauper180 »
Thanks for the replies, I found a reference to exit(1) that I removed and was able to get rid of that linking error.
Wilson
