Presenting the F3 Gizmo
Vic20
Post by Vic20 »
I have just publised in my blog the F3 Gizmo
http://r6500.blogspot.com.es/2014/04/presenting-f3-gizmo.html
This is a Forth like interactive environment for the STM32F3 Discovery that uses ChibiOS/RT as the underlying operating system.
You only need to burn the firmware and use a terminal emulator to comunicate with the system using Serial over USB.
In provides access to:
* The 8 user LEDs included in the board
* 10 Digital I/O pins in 5 configurable modes
* 3 PWM Digital outputs
* 6 Analog channels that can be configured in single ended or differential mode
* 1 Analog DAC Output
* 2 GPT Timers
* 1 SPI Bus
* 1 I2C Bus
* Access to the board Giroscope and Accelerometer/Magnetometer
It also implements the ChibiOS/RT threads, semaphores and mutexes
There are more links in the blog but these are the most important ones:
F3 Gizmo Manual v1.0 (2014-04-25).pdf
https://drive.google.com/file/d/0B0PzZrEvAdjVYVVCMHc4WndUTzg/edit?usp=sharing
CForth Manual v1.0 (2014-04-20).pdf
https://drive.google.com/file/d/0B0PzZrEvAdjVM24xc2NkeFMwa3c/edit?usp=sharing
Binary file: F3Gizmo_V1.0(2014-04-25).bin
https://drive.google.com/file/d/0B0PzZrEvAdjVV1M4QTFvM0Q0aVE/edit?usp=sharing
Sorces: F3Gizmo_V1.0(2014-04-25) Source.zip
https://drive.google.com/file/d/0B0PzZrEvAdjVQk5kUHJrRnpTY00/edit?usp=sharing
This is the first version and there could be some bugs hidding in the code.
Try it and say what do you think.
Re: Presenting the F3 Gizmo
This looks very well made. Thank you very much for sharing.
I've sent out a tweet. This could be quite interesting and helpful for many people.
Good work, thanks for sharing :)
