chMBPost ??
Tabulous
Has thanked: 7 times
Been thanked: 18 times
chMBPost ??
Post by Tabulous »
if i want to post a message from a EXTDriver callback which chMBPost would i use I-interrupt ?
i.e.
static void extcb1(EXTDriver *extp, expchannel_t channel)
struct iom m;
static VirtualTimer vt4;
    (void)extp;
    (void)channel;
    m.id = IOM_OUTPUT1;
    m.state = IOM_OUTPUT_ON;
    chMBPostI(&mbox, (msg_t)&m);
    chSysLockFromIsr();
    if (chVTIsArmedI(&vt4))
        chVTResetI(&vt4);
    /* LED4 set to OFF after 200mS.*/
    chVTSetI(&vt4, MS2ST(200), led1off, NULL);
    chSysUnlockFromIsr();
If so why would i be getting SV#10 panics ?
Re: chMBPost ??
Because you call the I-class function before chSysLockFromIsr(), it is supposed to be called within the critical zone.
Tabulous
Re: chMBPost ??
Post by Tabulous »
Giovanni wrote:Because you call the I-class function before chSysLockFromIsr(), it is supposed to be called within the critical zone.
Ok so if i used chMBPostS(&mbox, (msg_t)&m); i get SV#11
and
if i used chMBPost(&mbox, (msg_t)&m); i get SV#4
so how do i post to a message box from the EXTDriver Callback ?
Re: chMBPost ??
You need to use chMBPostI(), callbacks are called from ISR context.
Tabulous
Re: chMBPost ??
Post by Tabulous »
Giovanni wrote:You need to use chMBPostI(), callbacks are called from ISR context.
it doesnt work, this is what i have
struct iom m;
    (void)extp;
    (void)channel;
    m.id = IOM_OUTPUT1;
    chSysLockFromIsr();
        chVTResetI(&vt4);
I get debug panic SV#10, dbg_isr_cnt = 1 and dbg_lock_cnt = 0
Re: chMBPost ??
Because you call the I-class function (chMBPostI()) before chSysLockFromIsr(), it is supposed to be called within the critical zone.
Tabulous
Re: chMBPost ??
Post by Tabulous »
Giovanni wrote:Because you call the I-class function (chMBPostI()) before chSysLockFromIsr(), it is supposed to be called within the critical zone.
so if i move the call to chMBPostI() outside the chSysLockFromIsr() lock zone, would i call just chMBPost ?
Re: chMBPost ??
You can only call I-class functions from ISRs and callbacks.
    struct iom m;
        (void)extp;
        (void)channel;
        m.id = IOM_OUTPUT1;
        chSysLockFromIsr();
            chVTResetI(&vt4);
This.
