Help wit serial read and write data
I want to ask you wich is the best way to read and write data with SD1 constantly in the main thread.
Thank you very much
Thank you very much
Re: Help wit serial read and write data
You may use chprintf() or chnWriteTimeout(), example:
chprintf(&SD1, "Hello World!");
chnWriteTimeout(&SD1, "Hello World!", 12, TIME_INFINITE);
Thank you for your reply,
Maybe can you help me, I made this code and I don't understand why it did not work, thanks a lot and sorry about this kind of questions.
* Application entry point.
int main(void) {
* System initializations.
* and performs the board-specific initializations.
* RTOS is active.
sdStart(&SD1, NULL);
extStart(&EXTD1, &extcfg);
adcStart(&ADCD1, NULL);
* Initializes the ADC driver 1 and enable the thermal sensor.
* The pin PC1 on the port GPIOC is programmed as analog input.
//adcStart(&ADCD1, NULL);
//adcSTM32EnableTSVREFE();
palSetGroupMode(GPIOC, PAL_PORT_BIT(0) | PAL_PORT_BIT(1) | PAL_PORT_BIT(2) | PAL_PORT_BIT(3),0,PAL_MODE_INPUT_ANALOG);
//palSetPadMode(GPIOC, 0, PAL_MODE_INPUT_ANALOG);
palClearPad(GPIOE, GPIOE_DO1);
palClearPad(GPIOE, GPIOE_DO2);
palClearPad(GPIOE, GPIOE_DO3);
palClearPad(GPIOE, GPIOE_DO4);
while (TRUE) {
if(chSequentialStreamRead((BaseSequentialStream *)&SD1, (uint8_t *)&receive,1)==0)
chprintf((BaseSequentialStream *)&SD1,"values: %d \n",flag);
chThdSleepMilliseconds(100);
}- Giovanni
Are the serial TX and RX pins programmed as appropriate alternate functions? see the data sheet for details.
Thanks for your replies,
The pins are ok because with the code of the post viewtopic.php?f=2&t=1770 they work, but I have a lot of mistakes as you told me. I'm trying to correct it and now it looks like this, but I have a problem with the if sentence when i only write on the port it works fine but if I try to read the port the code does not work. I suppose that if the port is empty the chSequentialStreamRead() functions returns "0" and then write on the port.
Thank you very much again,
Adnil
#include "ch.h"
#include "chprintf.h"
#include <stdio.h>
#include <string.h>
#include "chconf.h"
static int8_t flag = 1;
uint8_t DI = 0, DO1 = 0, DOE=0;
uint16_t DI1E=0,DO=0;
uint16_t AI1=0, AI2=0, AI3=0, AI4=0;
char message[10];
char receive = 0;
static int8_t flagTx = 0, flagRv=0;
static void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n);
struct frame {
uint16_t AInput1;
uint16_t AInput2;
uint16_t AInput3;
uint16_t AInput4;
uint8_t DInput;
uint8_t state;
} values;
/* Digital Inputs*/
static void extcb1(EXTDriver *extp, expchannel_t channel) {
(void)extp;
(void)channel;
flag = 1;
{EXT_CH_MODE_DISABLED, NULL},
{EXT_CH_MODE_BOTH_EDGES | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOE, extcb1},
/* Total number of channels to be sampled by a single ADC operation.*/
#define ADC_GRP1_NUM_CHANNELS 4
/* Depth of the conversion buffer, channels are sampled four times each.*/
#define ADC_GRP1_BUF_DEPTH 32 // Número de muestras
#define N 5 // Corrimientos para la división 2^N = define ADC_GRP1_BUF_DEPTH
* ADC samples buffer.
static adcsample_t samples[ADC_GRP1_NUM_CHANNELS * ADC_GRP1_BUF_DEPTH];
* ADC conversion group.
* Mode: Linear buffer, ADC_GRP1_BUF_DEPTH samples of 4 channels, SW triggered.
* Channels: IN10 (48 cycles sample time)
* Channels: IN11 (48 cycles sample time)
* Channels: IN12 (48 cycles sample time)
* Channels: IN13 (48 cycles sample time)
static const ADCConversionGroup adcgrpcfg = {
FALSE,
ADC_GRP1_NUM_CHANNELS,
adccb,
NULL,
/* HW dependent part.*/
0,
ADC_CR2_SWSTART,
ADC_SMPR1_SMP_AN13(ADC_SAMPLE_56) | ADC_SMPR1_SMP_AN12(ADC_SAMPLE_56) | ADC_SMPR1_SMP_AN11(ADC_SAMPLE_56) | ADC_SMPR1_SMP_AN10(ADC_SAMPLE_56),
0,
ADC_SQR1_NUM_CH(ADC_GRP1_NUM_CHANNELS),
0,
ADC_SQR3_SQ4_N(ADC_CHANNEL_IN13) | ADC_SQR3_SQ3_N(ADC_CHANNEL_IN12) | ADC_SQR3_SQ2_N(ADC_CHANNEL_IN11) | ADC_SQR3_SQ1_N(ADC_CHANNEL_IN10)
* ADC end conversion callback.
* The PWM channels are reprogrammed using the latest ADC samples.
* The latest samples are transmitted into a single SPI transaction.
void adccb(ADCDriver *adcp, adcsample_t *buffer, size_t n) {
(void) buffer; (void) n;
/* Note, only in the ADC_COMPLETE state because the ADC driver fires an
intermediate callback when the buffer is half full.*/
if (adcp->state == ADC_COMPLETE) {
int i;
uint32_t avg1=0,avg2=0,avg3=0,avg4=0;
/* Calculates the average values from the ADC samples.*/
for (i=0;i<ADC_GRP1_BUF_DEPTH;i++){
avg1 += samples[4*i];
avg2 += samples[4*i+1];
avg3 += samples[4*i+2];
avg4 += samples[4*i+3];
AI1 = avg1 >> N;
AI2 = avg2 >> N;
AI3 = avg3 >> N;
AI4 = avg4 >> N;
adcStopConversion(&ADCD1);
int main(void) {
* RTOS is active.
while (TRUE) {
if (flag) {
DI1E = palReadPort(GPIOE);
DI = ((DI1E & 0x7C)>>2) | (DI1E & 0x80) | ((DI1E & 0x3000)>>7);
flag = 0;
values.DInput = DI;
values.state = DOE;
values.AInput1 = AI1;
values.AInput2 = AI2;
values.AInput3 = AI3;
values.AInput4 = AI4;
adcStartConversion(&ADCD1, &adcgrpcfg, samples, ADC_GRP1_BUF_DEPTH);
DO = palReadPort(GPIOE);
DOE = (DO & 0xF00)>>4;
memcpy(message, &values, sizeof (values));
chnWriteTimeout(&SD1, (const uint8_t *)&message, sizeof (values), TIME_INFINITE);
else
DO1 = receive;
if (DO1 == 10 || DO1 == 30|| DO1 == 50|| DO1 == 70){
palClearPad(GPIOE, GPIOE_DO4);}
else if (DO1 == 20)
palSetPad(GPIOE, GPIOE_DO1);
else if (DO1 == 40)
palSetPad(GPIOE, GPIOE_DO2);
else if (DO1 == 60)
palSetPad(GPIOE, GPIOE_DO3);
else if (DO1 == 80)
palSetPad(GPIOE, GPIOE_DO4);
//chSequentialStreamWrite((BaseSequentialStream *)&SD1, (const uint8_t *)&message, sizeof (values));
Adnil
Nope, it waits until the specified amount of data is received.
When I changed the functions of write and read the port and it works but i need to use a funtion like chSequentialStreamWrite for sending my data of 10 bytes. How can I make to work it. Thanks a lot.
#include "ch.h"
#include <stdio.h>
#include <string.h>
#include "chconf.h"
char message[10];
char receive = 0;
struct frame {
uint16_t AInput1;
uint16_t AInput2;
uint16_t AInput3;
uint16_t AInput4;
uint8_t DInput;
uint8_t state;
} values;
/* Digital Inputs*/
(void)extp;
(void)channel;
flag = 1;
FALSE,
adccb,
NULL,
0,
ADC_CR2_SWSTART,
0,
0,
int i;
AI1 = avg1 >> N;
AI2 = avg2 >> N;
AI3 = avg3 >> N;
AI4 = avg4 >> N;
int main(void) {
* RTOS is active.
while (TRUE) {
if (flag) {
flag = 0;
values.DInput = DI;
values.state = DOE;
if(chnWriteTimeout(&SD1, (const uint8_t *)&receive, 1, 50))
else
DO1 = receive;
else if (DO1 == 20)
else if (DO1 == 40)
else if (DO1 == 60)
else if (DO1 == 80)
