Vector Table Mapping Topic is solved
jbrandmeyer_bwp
Post by jbrandmeyer_bwp »
I see that the STM32F4 port supports remapping the NVIC vector table by re-defining CORTEX_VTOR_INIT, located in ARMCMx/STM32F4xx/cmparams.h. However, I would like to re-define this variable on a per-project basis. Due to the order of inclusion, re-defining it in chconf.h or with a compiler -D directive will not override the definition of this macro. Can the definition in cmparams.h be changed to a default definition? Ie,
#ifndef CORTEX_VTOR_INIT
#define CORTEX_VTOR_INIT 0x00000000
This way, it can be re-defined in chconf.h.
Re: Vector Table Mapping
It is not located in cmparams.h, it is located in chcore_v7m.h as follow:
 * @brief   NVIC VTOR initialization expression.
#if !defined(CORTEX_VTOR_INIT) || defined(__DOXYGEN__)
You just need to add
to chconf.h or as a -Dxxx in your makefile.
jbrandmeyer_bwp
Well, the egg is on my face. I think I made that modification (moving the definition from chcore_v7m.h to chparams.h) in my local copy.
