I have been able to get ChibiOS/RT working on Arduino ATmega328 and ATmega1280 processors but am having problems with the ATmega2560.
I believe the problem is due to the fact that the ATmega2560 has a 17-bit program counter. Subroutine calls and interrupts push three bytes on the stack. RET and RETI pop three bytes. ATmega328 and ATmega1280 push and pop two bytes for calls and interrupts.
Any suggestions for what needs to be modified to make the ATmega2560 work?
Problem with ATmega2560
Re: Problem with ATmega2560
You are correct, it is the AVR port layer that requires a change, the files are chcore.c and chcore.h under ./os/port/AVR, you have to update the context structures and the context switch routine.
Thanks, I have the ATmega2560 working with small test programs. I have not dealt with EIND, the Extended Indirect Register. I assume it is zero for small programs.
I added a byte to the extctx struct:
and the intctx struct:
And made two versions of the SETUP_CONTEXT macro:
struct extctx {
uint8_t _next;
uint8_t r31;
uint8_t r30;
uint8_t r27;
uint8_t r26;
uint8_t r25;
uint8_t r24;
uint8_t r23;
uint8_t r22;
uint8_t r21;
uint8_t r20;
uint8_t r19;
uint8_t r18;
uint8_t sr;
uint8_t r1;
uint8_t r0;
#if THREE_BYTE_PC
uint8_t pcx;
#endif // THREE_BYTE_PC
uint16_t pc;
};and the intctx struct:
struct intctx {
uint8_t _next;
uint8_t r29;
uint8_t r28;
uint8_t r17;
uint8_t r16;
uint8_t r15;
uint8_t r14;
uint8_t r13;
uint8_t r12;
uint8_t r11;
uint8_t r10;
#ifndef CH_CURRP_REGISTER_CACHE
uint8_t r9;
uint8_t r8;
uint8_t r7;
uint8_t r6;
uint8_t r5;
uint8_t r4;
uint8_t r3;
uint8_t r2;
#if THREE_BYTE_PC
uint8_t pcx;
uint8_t pcl;
uint8_t pch;
};And made two versions of the SETUP_CONTEXT macro:
#if THREE_BYTE_PC
#define SETUP_CONTEXT(workspace, wsize, pf, arg) { \
tp->p_ctx.sp = (struct intctx*)((uint8_t *)workspace + wsize - \
sizeof(struct intctx)); \
tp->p_ctx.sp->r2 = (int)pf; \
tp->p_ctx.sp->r3 = (int)pf >> 8; \
tp->p_ctx.sp->r4 = (int)arg; \
tp->p_ctx.sp->r5 = (int)arg >> 8; \
tp->p_ctx.sp->pcx = 0; \
tp->p_ctx.sp->pcl = (int)_port_thread_start >> 8; \
tp->p_ctx.sp->pch = (int)_port_thread_start; \
#else // THREE_BYTE_PC
