Speed issue with SSD1963 Library
himsha
Post by himsha »
Hi, i am working with SSD1963 7"TFT(800x480) with stm32f407 168 MHz discovery board, SSD1963 driver work fine initializing data bus and control pin as GPIO, but with slow response on TFT, right now refresh rate that I am able to achieve is 1 FPS.
As done a lot of search max. 30 FPS can be achieved using FSMC. I took example of darth and update according to my requirement, but some how its not working. Code is attached plz take a look and let me know what I am doing wrong.
https://www.sendspace.com/file/lsah1h
Re: Speed issue with SSD1963 Library
Cannot help, your project apparently is not even related to ChibiOS, you should try the ST forum.
Giovanni wrote:Cannot help, your project apparently is not even related to ChibiOS, you should try the ST forum.
And in case of you use the uGFX library to the uGFX forum.
