3.0.0 optimize speed bug?
Korken
Has thanked: 5 times
Been thanked: 6 times
Post by Korken »
I am hunting bugs in my system so I was going to follow the debugging guide in which is states that "#define CH_CFG_OPTIMIZE_SPEED" shall be false.
But when I do this I get these warnings (and more), and a lot of them:
../ChibiOS-RT/os/rt/src/chthreads.c: In function 'chThdExitS':
../ChibiOS-RT/os/rt/src/chthreads.c:385:5: warning: implicit declaration of function 'list_remove' [-Wimplicit-function-declaration]
chSchReadyI(list_remove(&tp->p_waiting));
../ChibiOS-RT/os/rt/src/chthreads.c: In function 'chThdDequeueAllI':
../ChibiOS-RT/os/rt/src/chthreads.c:635:20: warning: initialization makes pointer from integer without a cast [enabled by default]
thread_t *tp = queue_fifo_remove(tqp);
../ChibiOS-RT/os/rt/src/chmsg.c: In function 'chMsgWait':
../ChibiOS-RT/os/rt/src/chmsg.c:125:3: warning: implicit declaration of function 'queue_fifo_remove' [-Wimplicit-function-declaration]
tp = queue_fifo_remove(&currp->p_msgqueue);
Is this a possible bug or am I setting something incorrectly?
Best Regards
Emil Fresk
Re: 3.0.0 optimize speed bug?
It is possible it is a bug, 3.0 is no yet tested exhaustively through all the configuration switches.
Korken
Post by Korken »
Okey, then I will set it to TRUE for now.
It should be OK now.
