New compile bug?
Korken
Has thanked: 5 times
Been thanked: 6 times
New compile bug?
Post by Korken »
I just synced down the latest commits to 3.0.0, and whenever I try to compile now (a completely new and clean project, including demos, with FPU enabled) I get these errors:
Compiling chcore_v7m.c
Compiling chdebug.c
../ChibiOS-RT/os/rt/ports/ARMCMx/chcore_v7m.c: In function 'SVC_Handler':
../ChibiOS-RT/os/rt/ports/ARMCMx/chcore_v7m.c:67:3: error: 'SCB_FPCCR' undeclared (first use in this function)
SCB_FPCCR &= ~FPCCR_LSPACT;
../ChibiOS-RT/os/rt/ports/ARMCMx/chcore_v7m.c:67:3: note: each undeclared identifier is reported only once for each function it appears in
../ChibiOS-RT/os/rt/ports/ARMCMx/chcore_v7m.c:67:17: error: 'FPCCR_LSPACT' undeclared (first use in this function)
make: *** [build/obj/chcore_v7m.o] Error 1
And when I search the entire repository for FPCCR_LSPACT I cannot seem to find its definition.
Is this a new compile bug or have I made an error?
It works if you disable the FPU in:
ifeq ($(USE_FPU),)
  USE_FPU = softfp
endif
Edit: This is done with the STM32F4xx demos.
Best Regards
Emil
Korken
Re: New compile bug?
Post by Korken »
I have worked more on this and Bugfix #512 is the problematic commit.
In chcore_v7m.c:
#if CORTEX_USE_FPU
  /* Restoring the special register FPCCR.*/
  FPU->FPCCR = (uint32_t)ctxp->fpccr;
  FPU->FPCAR = FPU->FPCAR + sizeof (struct port_extctx);
is changed to
#if CORTEX_USE_FPU
  /* Enforcing unstacking of the FP part of the context.*/
which seems to be causing the problems since FPCCR_LSPACT is undefined.
Edit: Also SCB_FPCCR is only defined in crt0.c:
#define SCB_FPCCR               *((uint32_t *)0xE000EF34U)
Which also causes problems.
Yes, some 2.6 code slipped there, I will fix it ASAP.
Korken
Post by Korken »
Awesome! Thanks Giovanni!
Best Regards
Emil Fresk
Korken
Post by Korken »
I know you said ASAP, but do you have a time frame for the fix? :) I tried going back to an old commit, but I'm not that good with Git...
//Emil
You are not considering the "AP" part of ASAP.
Fixed but not tested yet.
Korken
Post by Korken »
It compiles at least :)
Thanks Giovanni!
