Beginners - Command Shell
Juzujka
Post by Juzujka »
ChibiOS 2.6.4, code extracted from Demos
LED Blinker included to ensure the board is live.
mcuconf.h used from demo. Check this lines if used other mcuconf.h
#define STM32_SERIAL_USE_USART1             TRUE
 * @brief   Enables the SERIAL subsystem.
#if !defined(HAL_USE_SERIAL) || defined(__DOXYGEN__)
#define HAL_USE_SERIAL              TRUE
/* SERIAL driver related settings.                                           */
 * @brief   Default bit rate.
 * @details Configuration parameter, this is the baud rate selected for the
 *          default configuration.
#if !defined(SERIAL_DEFAULT_BITRATE) || defined(__DOXYGEN__)
#define SERIAL_DEFAULT_BITRATE      38400
chconf.h
 * @brief   Managed RAM size.
#if !defined(CH_MEMCORE_SIZE) || defined(__DOXYGEN__)
#define CH_MEMCORE_SIZE                 0
main.c
#include <stdio.h>
#include <string.h>
#include "ch.h"
#include "shell.h"
#include "chprintf.h"
/* Command line related.                                                     */
#define SHELL_WA_SIZE   THD_WA_SIZE(512)
static void cmd_mem(BaseSequentialStream *chp, int argc, char *argv[]) {
  size_t n, size;
  (void)argv;
  if (argc > 0) {
    chprintf(chp, "Usage: mem\r\n");
    return;
  n = chHeapStatus(NULL, &size);
  chprintf(chp, "core free memory : %u bytes\r\n", chCoreStatus());
  chprintf(chp, "heap fragments   : %u\r\n", n);
  chprintf(chp, "heap free total  : %u bytes\r\n", size);
static void cmd_threads(BaseSequentialStream *chp, int argc, char *argv[]) {
  static const char *states[] = {THD_STATE_NAMES};
  Thread *tp;
  (void)argv;
  if (argc > 0) {
    chprintf(chp, "Usage: threads\r\n");
    return;
  chprintf(chp, "    addr    stack prio refs     state time\r\n");
  tp = chRegFirstThread();
  do {
    chprintf(chp, "%.8lx %.8lx %4lu %4lu %9s %lu\r\n",
            (uint32_t)tp, (uint32_t)tp->p_ctx.r13,
            (uint32_t)tp->p_prio, (uint32_t)(tp->p_refs - 1),
            states[tp->p_state], (uint32_t)tp->p_time);
    tp = chRegNextThread(tp);
  } while (tp != NULL);
static const ShellCommand commands[] = {
  {"mem", cmd_mem},
  {"threads", cmd_threads},
  {NULL, NULL}
static const ShellConfig shell_cfg1 = {
  (BaseSequentialStream *)&SD1,
  commands
/* Main and generic code.                                                    */
 * LEDs blinker thread, times are in milliseconds.
static WORKING_AREA(waThread1, 128);
  (void)arg;
  while (TRUE) {
    palSetPad(GPIOC, GPIOC_LED3);
    chThdSleepMilliseconds(250);
    palClearPad(GPIOC, GPIOC_LED3);
 * Application entry point.
int main(void) {
  Thread *shelltp = NULL;
   * System initializations.
   *   RTOS is active.
   * Activates the serial driver 1 and SDC driver 1 using default
   * configuration.
  sdStart(&SD1, NULL);
  //sdcStart(&SDCD1, NULL);
   * Shell manager initialization.
  shellInit();
   * Creates the blinker thread.
   * sleeping in a loop and listen for events.
  while (TRUE) {
    if (!shelltp)
      shelltp = shellCreate(&shell_cfg1, SHELL_WA_SIZE, NORMALPRIO);
    else if (chThdTerminated(shelltp)) {
      chThdRelease(shelltp);    /* Recovers memory of the previous shell.   */
      shelltp = NULL;           /* Triggers spawning of a new shell.        */
makefile - add sources from os/various/
# C sources that can be compiled in ARM or THUMB mode depending on the global
# setting.
CSRC = $(PORTSRC) \
       $(KERNSRC) \
       $(TESTSRC) \
       $(HALSRC) \
       $(PLATFORMSRC) \
       $(BOARDSRC) \
       ${CHIBIOS}/os/various/shell.c \
       ${CHIBIOS}/os/various/memstreams.c \
       $(CHIBIOS)/os/various/evtimer.c \
       $(CHIBIOS)/os/various/syscalls.c \
       $(CHIBIOS)/os/various/chprintf.c \
       main.c
INCDIR = $(PORTINC) $(KERNINC) $(TESTINC) \
         $(HALINC) $(PLATFORMINC) $(BOARDINC) \
