Kinetis support in trunk
Posted: Thu Aug 07, 2014 5:12 pm
Just finished adding support for some Kinetis parts which are now available on 3.0. I got preliminary support for KL25 (CM0+) and K20 (CM4). The boards with included demo are the Freescale Freedom KL25Z and K20D50M and the Teensy 3.0.
Much of the code comes from 2.6x port available on Github and some I wrote anew. Thanks also for the contributions/improvements made by colin and JCube.
And now the demo test outputs:
Freedom KL25Z:
Freedom K20D50M:
Teensy 3.0:
Best Regards,
Fabio Utzig
Freedom KL25Z:
*** ChibiOS/RT test suite
*** Kernel: 3.0.0dev
*** Compiled: Aug 7 2014 - 12:48:59
*** Compiler: GCC 4.8.4 20140526 (release) [ARM/embedded-4_8-branch revision 211358]
*** Architecture: ARMv6-M
*** Core Variant: Cortex-M0+
*** Port Info: Preemption through NMI
*** Platform: Kinetis
*** Test Board: Freescale Freedom KL25Z
--- Test Case 1.1 (Threads, enqueuing test #1)
--- Result: SUCCESS
--- Test Case 1.2 (Threads, enqueuing test #2)
--- Result: SUCCESS
--- Test Case 1.3 (Threads, priority change)
--- Result: SUCCESS
--- Test Case 1.4 (Threads, delays)
--- Result: SUCCESS
--- Test Case 2.1 (Semaphores, enqueuing)
--- Result: SUCCESS
--- Test Case 2.2 (Semaphores, timeout)
--- Result: SUCCESS
--- Test Case 2.3 (Semaphores, atomic signal-wait)
--- Result: SUCCESS
--- Test Case 2.4 (Binary Semaphores, functionality)
--- Result: SUCCESS
--- Test Case 3.1 (Mutexes, priority enqueuing test)
--- Result: SUCCESS
--- Test Case 3.2 (Mutexes, priority return)
--- Result: SUCCESS
--- Test Case 3.3 (Mutexes, status)
--- Result: SUCCESS
--- Test Case 3.4 (CondVar, signal test)
--- Result: SUCCESS
--- Test Case 3.5 (CondVar, broadcast test)
--- Result: SUCCESS
--- Test Case 3.6 (CondVar, boost test)
--- Result: SUCCESS
--- Test Case 4.1 (Messages, loop)
--- Result: SUCCESS
--- Test Case 5.1 (Mailboxes, queuing and timeouts)
--- Result: SUCCESS
--- Test Case 6.1 (Events, registration and dispatch)
--- Result: SUCCESS
--- Test Case 6.2 (Events, wait and broadcast)
--- Result: SUCCESS
--- Test Case 6.3 (Events, timeouts)
--- Result: SUCCESS
--- Test Case 7.1 (Heap, allocation and fragmentation test)
--- Result: SUCCESS
--- Test Case 8.1 (Memory Pools, queue/dequeue)
--- Result: SUCCESS
--- Test Case 9.1 (Dynamic APIs, threads creation from heap)
--- Result: SUCCESS
--- Test Case 9.2 (Dynamic APIs, threads creation from memory pool)
--- Result: SUCCESS
--- Test Case 9.3 (Dynamic APIs, registry and references)
--- Result: SUCCESS
--- Test Case 10.1 (Queues, input queues)
--- Result: SUCCESS
--- Test Case 10.2 (Queues, output queues)
--- Result: SUCCESS
--- Test Case 11.1 (Benchmark, messages #1)
--- Score : 157724 msgs/S, 315448 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.2 (Benchmark, messages #2)
--- Score : 124773 msgs/S, 249546 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.3 (Benchmark, messages #3)
--- Result: SUCCESS
--- Score : 486416 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.5 (Benchmark, threads, full cycle)
--- Score : 100185 threads/S
--- Result: SUCCESS
--- Test Case 11.6 (Benchmark, threads, create only)
--- Score : 142239 threads/S
--- Result: SUCCESS
--- Test Case 11.7 (Benchmark, mass reschedule, 5 threads)
--- Score : 39691 reschedules/S, 238146 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.8 (Benchmark, round robin context switching)
--- Score : 294540 ctxswc/S
--- Result: SUCCESS
--- Test Case 11.9 (Benchmark, I/O Queues throughput)
--- Score : 422964 bytes/S
--- Result: SUCCESS
--- Test Case 11.10 (Benchmark, virtual timers set/reset)
--- Score : 393390 timers/S
--- Result: SUCCESS
--- Test Case 11.11 (Benchmark, semaphores wait/signal)
--- Score : 767760 wait+signal/S
--- Result: SUCCESS
--- Test Case 11.12 (Benchmark, mutexes lock/unlock)
--- Score : 453020 lock+unlock/S
--- Result: SUCCESS
--- Test Case 11.13 (Benchmark, RAM footprint)
--- System: 460 bytes
--- Thread: 68 bytes
--- Timer : 20 bytes
--- Semaph: 12 bytes
--- EventS: 4 bytes
--- EventL: 16 bytes
--- Mutex : 16 bytes
--- CondV.: 8 bytes
--- Queue : 36 bytes
--- MailB.: 40 bytes
--- Result: SUCCESS
Final result: SUCCESS
Freedom K20D50M:
*** Compiled: Aug 7 2014 - 12:47:09
*** Architecture: ARMv7-ME
*** Core Variant: Cortex-M4
*** Port Info: Advanced kernel mode
*** Test Board: Freescale Freedom K20D50M
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 167099 msgs/S, 334198 ctxswc/S
--- Result: SUCCESS
--- Score : 133495 msgs/S, 266990 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 582816 ctxswc/S
--- Result: SUCCESS
--- Score : 99560 threads/S
--- Result: SUCCESS
--- Score : 143087 threads/S
--- Result: SUCCESS
--- Score : 41773 reschedules/S, 250638 ctxswc/S
--- Result: SUCCESS
--- Score : 317520 ctxswc/S
--- Result: SUCCESS
--- Score : 383104 bytes/S
--- Result: SUCCESS
--- Score : 405010 timers/S
--- Result: SUCCESS
--- Score : 663764 wait+signal/S
--- Result: SUCCESS
--- Score : 459524 lock+unlock/S
--- Result: SUCCESS
--- EventS: 4 bytes
--- CondV.: 8 bytes
--- Result: SUCCESS
Teensy 3.0:
*** Compiled: Aug 7 2014 - 12:44:14
*** Test Board: PJRC Teensy 3.0
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 167032 msgs/S, 334064 ctxswc/S
--- Result: SUCCESS
--- Score : 133438 msgs/S, 266876 ctxswc/S
--- Result: SUCCESS
--- Result: SUCCESS
--- Score : 582592 ctxswc/S
--- Result: SUCCESS
--- Score : 99520 threads/S
--- Result: SUCCESS
--- Score : 143029 threads/S
--- Result: SUCCESS
--- Score : 41756 reschedules/S, 250536 ctxswc/S
--- Result: SUCCESS
--- Score : 317400 ctxswc/S
--- Result: SUCCESS
--- Score : 382956 bytes/S
--- Result: SUCCESS
--- Score : 434294 timers/S
--- Result: SUCCESS
--- Score : 663504 wait+signal/S
--- Result: SUCCESS
--- Score : 459352 lock+unlock/S
--- Result: SUCCESS
--- EventS: 4 bytes
--- CondV.: 8 bytes
--- Result: SUCCESS
Best Regards,
Fabio Utzig
