Problem using time in microseconds
nikhil
Post by nikhil »
I want to use chThdSleepMicrosecond function. I have set CH_FREQUENCY to 1000000. But code hangs when call above function. Same code works fine when I call chThdSleepMilliseconds. Am I missing something? I am using chibios 2.6.5 with stm32f4.
Nikhil
Re: Problem using time in microseconds
There is a limit to the resolution you can get, the CPU is not able to serve 1000000 interrupts per second. See the GPT driver if you need higher resolutions. You may also use halPolledDelay().
