Problem using USB-Serial on STM32F407
LHelge
Post by LHelge »
I have some problems getting the USB serial functions to work on my STM32F4Discovery board. I've made my own project based mostly on the examples included in ChibiOS, but I cannot get the receive parts working. The USB code are copied straight from the STM32F4xx-USB_CDC example with the minor change from OTG2 to OTG1 to suit the STM32F4 discovery board.
I've made a, from what I can see, fairly straight forward echo program.
in my usbserial.c file i have these functions:
static WORKING_AREA(waFlashThread, 128);
static msg_t flashThread(void *arg) {
    (void)arg;
    while (TRUE) {
        if(isUsbSerialActive()) {
            chThdSleepMilliseconds(250);
        else {
            chThdSleepMilliseconds(500);
        palTogglePad(GPIOD, GPIOD_LED3);
    return 0;
void initUsbSerial(void) {
      sduObjectInit(&SDU1);
      sduStart(&SDU1, &serusbcfg);
      chThdSleepMilliseconds(1500);
      chThdCreateStatic(waFlashThread, sizeof(waFlashThread), NORMALPRIO-1, flashThread, NULL);
bool isUsbSerialActive(void) {
    return (SDU1.config->usbp->state == USB_ACTIVE);
void writeUsbSerial(uint8_t *buf, uint32_t len) {
        chSequentialStreamWrite(&SDU1, buf, len);
uint32_t readUsbSerial(uint8_t *buf, uint32_t len) {
        return chSequentialStreamRead(&SDU1, buf, len);
    return 0;
And in my main.c i have these
int main(void) {
  uint8_t buf[128];
  uint32_t n;
  initUsbSerial();
  while (TRUE) {
      if (isUsbSerialActive()) {
        n = readUsbSerial(buf, 128);
        writeUsbSerial(buf, n);
      if(n > 0) {
        palSetPad(GPIOD, GPIOD_LED4);
      n = 0;
      palClearPad(GPIOD, GPIOD_LED4);
The only problem is that I don't get anything back, and LED4 stays dark. I've verified that the connection is good, the USB device gets enumerated, LED3 starts flashing quicker, and the send function works fine. If I just set it to send a constant sting the message is received by my terminal. What have I done wrong?
wizhippo
Re: Problem using USB-Serial on STM32F407
Post by wizhippo »
I have success using the demo specific for that board. Take a look at ARMCM4-STM32F407-DISCOVERY-MEMS demo project.
I can't tell from your description how you have set up your project, but the basing your project off this demo project should almost guarantee you success with that board.
LHelge
Post by LHelge »
Fore some reason chSequentioalStreamGet() works but not chSequentialStreamRead(). Can't say why but it'll do it for now.
