Starting to add Nucleo F334R8
jcw
Post by jcw »
I noticed that the STM32F334 wasn't in the list of chips yet, so I started adding the necessary headers - I basically started from the STM32F30x files and the Nucleo F103RB board files, assuming that these would be closest to the desired result.
Going fine so far, but I'm hitting an error I can't quite figure out...
Compiling hal.c
In file included from ../chibios/os/hal/include/st.h:50:0,
                 from ../chibios/os/hal/include/hal.h:64,
                 from ../chibios/os/hal/src/hal.c:29:
../chibios/os/hal/ports/STM32/LLD/TIMv1/st_lld.h:69:2: error: #error "TIM2 not present"
I suspect that somewhere there's still an old path reference lurking in there?
(Feel free to add into the repo, of course - I can resubmit once this is solved)
-jcw
st334.diff.zip
(35.06 KiB) Downloaded 421 times
Re: Starting to add Nucleo F334R8
The F334 should already be supported after the inclusion of the new headers, isn't it? you have to use the same paths of the F30x (which should be renamed to F3xx).
jcw
Post by jcw »
Ah - I was confused because there is an F30x and an F37x, so I thought the logical step would be to add F33x?
Ok, I'll try the F30x route, thanks.
-jcw
F37x is a special case, it is different from the others. All other devices have the same clock tree and a common set of peripherals.
jcw
Post by jcw »
No joy, I'm still getting the "TIM2 not present" error.
Attached the board definitions I'm now using, along with these lines in my Makefile:
include $(CHIBIOS)/os/hal/boards/ST_NUCLEO_F334R8/board.mk
include $(CHIBIOS)/os/hal/ports/STM32/STM32F30x/platform.mk
include $(CHIBIOS)/os/hal/hal.mk
include $(CHIBIOS)/os/hal/osal/rt/osal.mk
include $(CHIBIOS)/os/rt/rt.mk
include $(CHIBIOS)/os/rt/ports/ARMCMx/compilers/GCC/mk/port_stm32f30x.mk
# Define linker script file here
LDSCRIPT= $(PORTLD)/STM32F334x8.ld
FWIW, the "STM32F334x8.ld" file is as follows, though that point is not being reached yet:
MEMORY
    flash : org = 0x08000000, len = 64k
    ram : org = 0x20000000, len = 12k
    ccmram : org = 0x10000000, len = 4k
INCLUDE rules.ld
What am I missing? I do not see any substantial differences between ST_NUCLEO_F334R8 and say ST_NUCLEO_F401RE board files.
-jcw
ST_NUCLEO_F334R8.zip
(9.15 KiB) Downloaded 437 times
Is the device identification macro correct?
jcw
Post by jcw »
I think so, this is in STM32F30x/cmparams.h:
#if !defined (STM32F301x8) && !defined (STM32F318xx) &&                     \
    !defined (STM32F302x8) && !defined (STM32F302xC) &&                     \
    !defined (STM32F303x8) && !defined (STM32F303xC) &&                     \
    !defined (STM32F358xx) && !defined (STM32F334x8) &&                     \
    !defined (STM32F328xx)
#include "board.h"
This is in my project: #define STM32F30x_MCUCONF
And this is in ST_NUCLEO_F334R8/board.h: #define STM32F334x8
-jcw
I am porting the Nucleo demos to 3.0 and did some rework on the F3 HAL, I will give F334 a try in the weekend.
Found the problem with the F334, added a demo but it is untested.
jcw
Post by jcw »
Woohoo - the demo and my test project are now compiling! Will test further soon, thank you!
-jcw
