I2C EEPROM - Random Read
Tabulous
Has thanked: 7 times
Been thanked: 18 times
Post by Tabulous »
I have a 24AA02E48 E2Prom on my board, what i want to do is read from a specific address 6 bytes.
I.e. read from 0xFA and the next 6 bytes.
But i'm struggling to see how this can be done, this is what i've got but it does not work.
static msg_t readMacAddress(void)
msg_t status = RDY_OK;
systime_t tmo = MS2ST(100);
    i2cAcquireBus(&I2CD3);
    i2c_state.txbuf[0] = 0xFA;
    i2c_state.address = E2PROM_ADDR;
    status = i2cMasterTransmitTimeout(&I2CD3,
                                      i2c_state.address,
                                      i2c_state.txbuf, 1,
                                      i2c_state.rxbuf, 0,
                                      tmo);
    status = i2cMasterReceiveTimeout(&I2CD3,
                                     i2c_state.address,
                                     i2c_state.rxbuf, 6,
                                     tmo);
    i2cReleaseBus(&I2CD3);
    return(status);
Re: I2C EEPROM - Random Read
I don't know the exact protocol, are you sure you need a separate receive after the transmit?
Tabulous
Post by Tabulous »
I'm not sure really
The Datasheet states the following
START
ADDRESS THE CHIP(WRITE)
ACK
ADDRESS OF MEM LOCATION
ACK
START
ADDRESS THE CHIP(READ)
ACK
DATA FROM THE CHIP
NO ACK
STOP
Then apparently you don't need the receive because there is no STOP and then again START.
steved
Has thanked: 12 times
Been thanked: 138 times
Post by steved »
You can usually read back as a single Chibi operation; send one, two or three address bytes (dependent on device) to set the memory start address, then read the required number of bytes.
Example using a 2-byte address:
// Function retrieves a block of memory from NV Memory
msg_t retrieveConfigMem(unsigned int memStart, uint8_t *data, unsigned int maxRead)
    msg_t   result;
    if (maxRead == 0) return(0);            // Implied success if nothing to do
    if (maxRead > sizeof(tempBuf.storedData)) return(-2);
    memset(&tempBuf,0, sizeof(tempBuf));
    tempBuf.memAddress[0] = (memStart >> 8) & 0xff;       // Address MSB
    tempBuf.memAddress[1] = memStart & 0xff;              // Address LSB
    i2cAcquireBus(&NVR_I2C_PORT);
    result = i2cMasterTransmitTimeout(&NVR_I2C_PORT, NVR_I2C_ADDRESS/2, (uint8_t *)&tempBuf, 2, (uint8_t *)&tempBuf.crc, maxRead + NVR_BUFFER_OVERHEAD - 2, NVR_I2C_TIMEOUT);
    i2cReleaseBus(&NVR_I2C_PORT);
    if (result != 0)
        return(result);
    if (tempBuf.dataSize > (int)sizeof(tempBuf.storedData))
        tempBuf.dataSize = sizeof(tempBuf.storedData);  // In case of garbage
    memcpy(data, tempBuf.storedData, tempBuf.dataSize);
    return(0);
This example goes via an intermediate buffer, because I actually add a header and CRC onto the data, but you can certainly read direct into your destination RAM if you want.
Tabulous
Post by Tabulous »
I've changed my routine to this
                                      i2c_state.address,
                                      i2c_state.txbuf, 1,
                                      i2c_state.rxbuf, 1,
                                      tmo);
The issue i have is the address been written out on the scope is not what it should be....... E2PROM_ADDR is 0xA0
But what is on the scope is 0XF0 see scope picture attached
Scope Trace
Scope Trace
Tabulous
Post by Tabulous »
Right guys i think there is an issue here in the driver.
My last post showed a scope trace, showing what comes out of the I2C bus.
For me to get this to work i have to have E2PROM_ADDR set to 0x50, if i want 0xA0 to come out of the bus.
Why should i need to offset the address by one shift to the right i.e 0xA0 >> 1
That parameter is just the address field without the RW bit.
Tabulous
Post by Tabulous »
Giovanni wrote:That parameter is just the address field without the RW bit.
yeah its just clicked :oops:
