static ADCConversionGroup xADCConfig = {
/* Circular */
FALSE,
/* 2, /\* Current Sense, Force Sense *\/ */
/* Test, PA7/ADC_IN7 */
1,
/* Callback */
cbADCDSP,
/* Error Callback */
cbADCError,
/* CFGR1 */
ADC_CFGR1_EXTEN_0
| ADC_CFGR1_EXTSEL_1
| ADC_CFGR1_EXTSEL_0
| ADC_CFGR1_RES_12BIT,
/* TR */
0,
/* SMPR */
ADC_SMPR_SMP_1P5,
/* ADC_SMPR_SMP_239P5, */
ADC_CHANNELS
adcsample_t* vADCConfig(void) {
adcObjectInit(&ADCD1);
adcStart(&ADCD1, NULL);
return adc_samples;
void vADCStart(void) {
/* Test */
palSetGroupMode(GPIOA, PAL_PORT_BIT(7),
0, PAL_MODE_INPUT_ANALOG);
adcStartConversion(&ADCD1, &xADCConfig, adc_samples, ADC_BUF_DEPTH);
void cbADCDSP(ADCDriver* adcp, adcsample_t *buffer, size_t n) {
(void) adcp;
(void) n;
/* chprintf((BaseSequentialStream*)&SD1, "ADC: %d\r\n", *buffer); */
chprintf(&SD1, "ADC\r\n");
static const GPTConfig xTIM3Config = {
/* Frequency */
50000,
/* Callback */
cbTIM3,
/* Dier */
TIM_DIER_TIE
| TIM_DIER_UIE
void vTIM3Config(void) {
gptObjectInit(&GPTD3);
gptStart(&GPTD3, &xTIM3Config);
/* TRGO Event */
GPTD3.tim->CR2 &= ~TIM_CR2_MMS;
GPTD3.tim->CR2 |= TIM_CR2_MMS_1;
void vTIM3Start(void) {
gptStartContinuous(&GPTD3, 25000);
The idea of these code is to start the timer, then turn on the master mode trigger event from timer update, and configure ADC1 to use that event to initiate conversion.
In main(), I just call vTIM3Config(), vADCConfig(), vTIM3Start(), vADCStart() in sequence and do infinite loop. In serial monitor, I found that ADC interrupt only enters once. However, the LED that is toggled in timer interrupt is flashing, so probably there is nothing wrong about timers.
