#include "ch.h"
// 'tick' values, only use standard (no overdrive) timing
int A = 6,B = 64,C = 60,D = 10,E = 9,F = 55,G = 0,H = 480,I = 70,J = 410;
// Pause for exactly 'tick' number of ticks = 0.25us
inline void tickDelay(int tick)
chThdSleepMicroseconds(tick);
// Generate a 1-Wire reset, return 1 if no presence detect was found,
// return 0 otherwise.
// (NOTE: Does not handle alarm presence from DS2404/DS1994)
int OWTouchReset(void)
int result;
tickDelay(G);
palSetPadMode(GPIOC, GPIOC_1WIRE, PAL_MODE_OUTPUT_OPENDRAIN);
palWritePad(GPIOC, GPIOC_1WIRE, PAL_LOW);
tickDelay(H); // Sleep 1920 microseconds
palWritePad(GPIOC, GPIOC_1WIRE, PAL_HIGH); // Releases the bus
tickDelay(I);
palSetPadMode(GPIOC, GPIOC_1WIRE, PAL_MODE_INPUT);
result = palReadPad(GPIOC, GPIOC_1WIRE) ^ 0x01; // Sample for presence pulse from slave
tickDelay(J); // Complete the reset sequence recovery
return result; // Return sample presence pulse result
// Send a 1-Wire write bit. Provide 10us recovery time.
// int A = 6,B = 64,C = 60,D = 10,E = 9,F = 55,G = 0,H = 480,I = 70,J = 410;
void OWWriteBit(int bit)
if (bit)
// Write '1' bit
palWritePad(GPIOC, GPIOC_1WIRE, PAL_LOW); // Drives DQ low
tickDelay(A);
tickDelay(B); // Complete the time slot and 10us recovery
else
// Write '0' bit
tickDelay(C);
tickDelay(D);
// Read a bit from the 1-Wire bus and return it. Provide 10us recovery time.
int OWReadBit(void)
int result;
tickDelay(A);
tickDelay(E);
result = palReadPad(GPIOC, GPIOC_1WIRE) & 0x01; // Sample the bit value from the slave
tickDelay(F); // Complete the time slot and 10us recovery
return result;
// Write 1-Wire data byte
void OWWriteByte(int data)
int loop;
// Loop to write each bit in the byte, LS-bit first
for (loop = 0; loop < 8; loop++)
OWWriteBit(data & 0x01);
// shift the data byte for the next bit
data >>= 1;
// Read 1-Wire data byte and return it
int OWReadByte(void)
int loop, result=0;
// shift the result to get it ready for the next bit
result >>= 1;
// if result is one, then set MS bit
if (OWReadBit())
result |= 0x80;
return result;
// Write a 1-Wire data byte and return the sampled result.
int OWTouchByte(int data)
int loop, result=0;
result >>= 1;
// If sending a '1' then read a bit else write a '0'
if (data & 0x01)
if (OWReadBit())
result |= 0x80;
else
OWWriteBit(0);
data >>= 1;
return result;
// Write a block 1-Wire data bytes and return the sampled result in the same
// buffer.
void OWBlock(unsigned char *data, int data_len)
int loop;
for (loop = 0; loop < data_len; loop++)
data[loop] = OWTouchByte(data[loop]);
void Read_ROMCode(void)
int n;
char dat[9];
chprintf(&SD2, "\nReading ROM Code\n");
OWTouchReset();
OWWriteByte(0x33);
for (n=0;n<8;n++)
dat[n]=OWReadByte();
chprintf(&SD2, "\n ROM Code = %X%X%X%X\n",dat[7],dat[6],dat[5],dat[4],dat[3],dat[2],dat[1],dat[0]);
Finally, could this be a good addition to the ChibiOS HAL layer?
