Interrupt when pin high
hkerner
Post by hkerner »
Does anyone know of a way to set up an interrupt to trigger when a certain pin is high? I don't see predefined functions for this in the HAL drivers. Any help is appreciated. Thank you in advance!!
hkerner
Re: Interrupt when pin high
Post by hkerner »
I need an interrupt for when H10, H11, H12, and I0 go high. Would I use the EXT driver with a config structure like this?
static const EXTConfig extHcfg = {
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOI, motScb},
    {EXT_CH_MODE_DISABLED, NULL},
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOH, motXcb}, // 10
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOH, motYcb}, // 11
    {EXT_CH_MODE_RISING_EDGE | EXT_CH_MODE_AUTOSTART | EXT_MODE_GPIOH, motZcb}, // 12
The configuration looks correct.
