I have recently been using ChibiOS, and now I have to develop a project that unites: STM32F103 + ChibiOS + uIP + ENC28J60 (Ethernet module).
STM32F103C8T6 controller and compiler Keil.
I'm using some code Josef Gajdusek (atalax) of https://github.com/atalax/reflow-controller
What is working:
SPI communication with ENC28J60 works correctly (main/enc.c).
uIP handles packages responds to Ping and displays HTML + CSS + JS on http-request (main/http.c).
ChibiOS has two threads:
- Connected to the network,
- Blinker with reinitialization SPI and ENC on the button.
I have the following problem.
- Usually when a large traffic (hundreds and more Ping per second), network_thread freezes (stops and process packets from the network), but ThreadBlink keeps flashing LED. If you then press a button and ThreadBlink reinitialize SPI and ENC, then ThreadBlink stop flashing immediately.
- Can freeze both at the same threads.
Freeze, system reside in _idle_thread, forever.
This may work for 1 minute or 1 hour, but in the end anyway stop. Only helps restart.
I guess I somehow wrong manages the threads that they stop working.
You can look at the code:
https://github.com/JonBAL/STM32-ChibiOS-uIP-ENC28J60
#include "main.h"
#include "stm32f10x.h"
#include "ch.h"
#include "enc.h"
#include "uip.h"
#include "uip_arp.h"
#include "evtimer.h"
// Указатель на поток
Thread *tp = NULL;
Thread *tp2 = NULL;
// Структура связи с ENC60J28
struct enc encST = {
&SPID1,
NULL,
GPIOA,
GPIOA_ENC_CS,
SPI_CR1_BR_0 | SPI_CR1_BR_1
(uint8_t) 0,
(uint16_t) 0,
ETHADDR0, ETHADDR1, ETHADDR2, ETHADDR3, ETHADDR4, ETHADDR5
static const struct uip_eth_addr macaddr = {
{ETHADDR0, ETHADDR1, ETHADDR2, ETHADDR3, ETHADDR4, ETHADDR5}
static EVENTSOURCE_DECL(enc_int_es);
static void enc_int(EXTDriver *drv, expchannel_t c)
(void)drv;
(void)c;
chEvtBroadcast(&enc_int_es);
{EXT_CH_MODE_DISABLED, NULL},
{EXT_CH_MODE_FALLING_EDGE | EXT_MODE_GPIOA | EXT_CH_MODE_AUTOSTART, enc_int},
#define EVID_NET_INT 0
#define EVID_NET_PERIODIC 1
#define EVID_NET_ARP 2
static void network_send()
if (uip_len <= UIP_LLH_LEN + 40)
enc_packet_send(&encST, uip_len, uip_buf, 0, NULL);
else
enc_packet_send(&encST, 54, uip_buf,
uip_len - UIP_LLH_LEN - 40, uip_appdata);
// СЕТЬ
static WORKING_AREA(network_wa, 512);
static msg_t network_thread(void *arg)
uip_ipaddr_t ip = {0 , 0};
EvTimer per_evt;
EvTimer arp_evt;
EventListener per_el;
EventListener arp_el;
EventListener int_el;
eventmask_t event;
int i;
uint8_t flags;
uint8_t count = 0;
(void)arg;
tp2 = chThdSelf();
evtInit(&per_evt, MS2ST(1000));
evtInit(&arp_evt, S2ST(10));
chEvtRegister(&per_evt.et_es, &per_el, EVID_NET_PERIODIC);
chEvtRegister(&arp_evt.et_es, &arp_el, EVID_NET_ARP);
chEvtRegister(&enc_int_es, &int_el, EVID_NET_INT);
spiStart(&SPID1, &encST.config);
enc_init(&encST);
uip_init();
uip_setethaddr(macaddr);
//uip_ipaddr(ip, IPADDR0, IPADDR1, IPADDR2, IPADDR3);
//uip_sethostaddr(ip);
uip_ipaddr(ip, 192,168,1,111);
uip_ipaddr(ip, 192,168,1,100);
uip_setdraddr(ip);
uip_ipaddr(ip, 255,255,255,0);
uip_setnetmask(ip);
uip_listen(HTONS(80));
evtStart(&per_evt);
evtStart(&arp_evt);
while (1)
if (!palReadPad(GPIOA, GPIOA_ENC_INT))
event = EVENT_MASK(EVID_NET_INT);
else
chSysLock();
palClearPad(GPIOB, GPIOB_PIN0);
event = chEvtWaitAny(ALL_EVENTS);
palSetPad(GPIOB, GPIOB_PIN0);
chSysUnlock();
if (event == EVENT_MASK(EVID_NET_INT))
/* The interrupt line is low for as long as we have packets pending */
flags = enc_int_flags(&encST);
if (flags & ENC_PKTIF)
while ((uip_len = enc_packet_receive(&encST, UIP_BUFSIZE, uip_buf)) != 0)
switch(ntohs((((struct uip_eth_hdr *)&uip_buf[0])->type)))
case UIP_ETHTYPE_IP:
uip_arp_ipin();
uip_input();
if (uip_len > 0)
uip_arp_out();
network_send();
break;
case UIP_ETHTYPE_ARP:
uip_arp_arpin();
if (uip_len > 0)
network_send();
break;
default: /* This usually happens on overflows, hackish but works */
enc_init(&encST);
chSysLock();
palTogglePad(GPIOB, GPIOB_PIN1);
chSysUnlock();
break;
enc_int_clear(&encST, ENC_ALLIF);
/* TODO: This patches the race condition, fix... */
chThdSleepMicroseconds(100);
else if (event == EVENT_MASK(EVID_NET_PERIODIC))
for (i = 0; i < UIP_CONNS; i++)
uip_periodic(i);
if (uip_len > 0)
uip_arp_out();
network_send();
else
uip_arp_timer();
count++;
if (count == 10)
count = 0;
chSysLock();
palTogglePad(GPIOB, GPIOB_PIN2);
chSysUnlock();
// МИГАЛКА
static WORKING_AREA(waThreadBlink, 128);
static msg_t ThreadBlink(void *arg)
while (1)
chSysLock();
palTogglePad(GPIOB, GPIOB_PIN7);
if (palReadPad(GPIOA, GPIOB_PIN15) == 1)
palTogglePad(GPIOB, GPIOB_PIN5);
spiStop(&SPID1);
enc_init(&encST);
chSysUnlock();
chThdSleepMilliseconds(200);
int main(void)
spiInit();
extInit();
chEvtInit(&enc_int_es);
extStart(&EXTD1, &extcfg);
chThdCreateStatic(network_wa, sizeof(network_wa), NORMALPRIO, network_thread, NULL);
chThdCreateStatic(waThreadBlink, sizeof(waThreadBlink), NORMALPRIO, ThreadBlink, NULL);
while (1)
chThdSleepMilliseconds(500);
