STM324Discovery+LAN8720
DGW
Post by DGW »
Good day to All. I repeated your project ARMCM4-STM32F407-LWIP for KEIL v4.74, but I use a chip ethernet LAN8720. Launch and begin to ping the device. After a few pings (ping -t -l 1400 192.168.1.204) the device freezes. What to do? If you need I can send the project. Thank you for help!
Re: STM324Discovery+LAN8720
Hard to do tests without hardware and it is hard to debug by just looking at code.
You should detail the nature of those freezes, do you have the debug options enabled in chconf.h? if so, is an error caught?
DGW
Post by DGW »
put a break point in the procedure chDbgPanic. Get into it and see what dbg_panic_msg indicates the message "SV#4". It's about something said?
SV#4 means that there is a problem in your code, the meaning is:
 *            - SV#1, misplaced @p chSysDisable().
 *              - Called from an ISR.
 *              - Called from a critical zone.
 *            - SV#2, misplaced @p chSysSuspend()
 *            - SV#3, misplaced @p chSysEnable().
 *            - SV#4, misplaced @p chSysLock().
 *            - SV#5, misplaced @p chSysUnlock().
 *              - Not called from a critical zone.
 *            - SV#6, misplaced @p chSysLockFromISR().
 *              - Not called from an ISR.
 *            - SV#7, misplaced @p chSysUnlockFromISR().
 *            - SV#8, misplaced @p CH_IRQ_PROLOGUE().
 *              - Not called at ISR begin.
 *            - SV#9, misplaced @p CH_IRQ_EPILOGUE().
 *              - @p CH_IRQ_PROLOGUE() missing.
 *              - Not called at ISR end.
 *            - SV#10, misplaced I-class function.
 *              - I-class function not called from within a critical zone.
 *            - SV#11, misplaced S-class function.
 *              - S-class function not called from within a critical zone.
You have two consecutive chSysLock() somewhere or you call that from an ISR.
DGW
Post by DGW »
Interestingly, if
#define CH_DBG_SYSTEM_STATE_CHECK TRUE
SV # 4 happens during initialization tasks "lwip_thread", and if
#define CH_DBG_SYSTEM_STATE_CHECK FALSE
see the situation described above (a few pings).
After the stop you can see exactly where it occurred by looking at the stack trace.
DGW
Post by DGW »
Giovanni, I am sorry, but I can send you a demo project?
Sorry but it is not physically possible for me to do debugging for users, I have a job and ChibiOS is already on top of that. In your case I don't even have the required hardware.
The kind of free support I can give in this forum is to answer specific questions and try to help users to solve their technical problems with suggestions and generic guidance. Of course if there is a suspect of a problem in ChibiOS code itself I usually am much more proactive.
If you make your code visible in the forum it is more likely that me or somebody else could find evident problems but more code you post and less likely is that something is found.
DGW
Post by DGW »
ok, as you send the project (folder with the project)?
You can post it as a zip file on the forum in case somebody want to give it a look.
