chibios_rt::Timer
Thargon
Has thanked: 15 times
Been thanked: 24 times
chibios_rt::Timer
Post by Thargon »
Hi guys,
I'm trying to implement some state machine like behaviour and would like to use a timer to trigger an upcoming state.
I just want to wait for some time and then trigger an event for one specific thread (no broadcast).
Since evereything else is done in C++, I would prefer to use the provided C++ class chibios_rt::Timer.
Unfortunately, all member function of that class are I-Class API functions and I can't get them to work.
If I don't use chSysLock() and chSysUnlock() I get the SV#10 error (misplaced I-class function) as expected.
But when I try to lock the system via chSysLock() I get the SV#4 error (misplaced chSysLock()).
Since I can't find any example on the net how to use the Timer class, maybe someone of you can provide some help :)
Thanks in advance!
Thargon
Re: chibios_rt::Timer
SV#4 means that you call chSysLock() twice, use the debugger stack trace and see where this happens.
Thargon
Post by Thargon »
thanks for your quick reply.
If that was the case, why do I get SV#10 without chSysLock()?
Maybe I don't understand the locking system yet, but I can't find a good explanation in the documentation.
The documentation just states
Function Class:
Special function, this function has special requirements see the notes.
So far I was unable to find these notes.
Thargon
Read the "Kernel Concepts" section into the general documentation, classes are described there.
http://chibios.sourceforge.net/html/concepts.html
Thargon
Post by Thargon »
Hi again,
thanks for the link, though it didn't help me in this particular case :(
I don't have a dev board at hand right now, so I cant use the debugger stack trace.
What I just did, was to read the dbg_lock_cnt and isr_lock_cnt variables (which seem to be relevant for the SV#4 error) just before I call chSysLock(). Both are 0, though I can't guarantee that nothing happens between the two calls.
Any further Ideas or examples?
Thank you for your help!
Thargon
If both variables are set to zero then you should not get that SV#4, it is hard for me to imagine what could be wrong there if you don't inspect with a debugger.
You need to single step through it and see which check fails.
