ITM stream
JoVM
ITM stream
Post by JoVM »
I'm building a stream for the ITM trace port to stream system formatted print. I took serial.c code as a guide. sdIncomingDataI and sdRequestDataI are called from the serial interrupts. I only need to write to the ITM port but without interrupts. Do I need to regularly poll the out queue? Or is there a better way?
Kr,Jo
Re: ITM stream
The serial driver assumes interrupts because it use queues, you should instead create your own object implementing the BaseSequentialStream interface. Your code would not use queues and just do polling.
I did something similar here:
    SPC5 HAL - Copyright (C) 2013 STMicroelectronics
 * @file    uartstream.c
 * @brief   UART streams code.
 * @addtogroup uart_stream
#include "uartstream.h"
/* Driver local definitions.                                                 */
#define SPC5_LINFLEX2_CLK                   100000000
 * @name    UARTSR register bits definitions
#define SPC5_UARTSR_NF                      (1U << 0)
#define SPC5_UARTSR_DTF                     (1U << 1)
#define SPC5_UARTSR_DRF                     (1U << 2)
#define SPC5_UARTSR_WUF                     (1U << 5)
#define SPC5_UARTSR_RPS                     (1U << 6)
#define SPC5_UARTSR_BOF                     (1U << 7)
#define SPC5_UARTSR_FEF                     (1U << 8)
#define SPC5_UARTSR_RMB                     (1U << 9)
#define SPC5_UARTSR_PE0                     (1U << 10)
#define SPC5_UARTSR_PE1                     (1U << 11)
#define SPC5_UARTSR_PE2                     (1U << 12)
#define SPC5_UARTSR_PE3                     (1U << 13)
#define SPC5_UARTSR_OCF                     (1U << 14)
#define SPC5_UARTSR_SZF                     (1U << 15)
 * @name    UARTCR register bits definitions
#define SPC5_UARTCR_UART                    (1U << 0)
#define SPC5_UARTCR_WL                      (1U << 1)
#define SPC5_UARTCR_PCE                     (1U << 2)
#define SPC5_UARTCR_OP                      (1U << 3)
#define SPC5_UARTCR_TXEN                    (1U << 4)
#define SPC5_UARTCR_RXEN                    (1U << 5)
#define SPC5_UARTCR_TFBM                    (1U << 8)
 * @name    Serial driver allowable modes
#define SD_MODE_8BITS_PARITY_NONE           (SPC5_UARTCR_WL)
#define SD_MODE_8BITS_PARITY_EVEN           (SPC5_UARTCR_WL |               \
                                             SPC5_UARTCR_PCE)
#define SD_MODE_8BITS_PARITY_ODD            (SPC5_UARTCR_WL |               \
                                             SPC5_UARTCR_PCE |              \
                                             SPC5_UARTCR_OP)
/* Driver exported variables.                                                */
/* Driver local variables.                                                   */
/* Driver local functions.                                                   */
static msg_t put(void *ip, uint8_t b) {
  (void)ip;
  while (LINFlexD_2.UARTSR.B.DTFTFF)
  LINFlexD_2.BDRL.B.DATA0 = b;
  return MSG_OK;
static msg_t get(void *ip) {
  (void)ip;
  return 4;
static size_t writes(void *ip, const uint8_t *bp, size_t n) {
  size_t cnt = n;
  while (cnt > 0) {
    put(ip, *bp);
    bp++;
    cnt--;
  return n;
static size_t reads(void *ip, uint8_t *bp, size_t n) {
  (void)ip;
  (void)bp;
  (void)n;
  return 0;
static const struct UartStreamVMT vmt = {writes, reads, put, get};
/* Driver exported functions.                                                */
 * @brief   UART stream object initialization.
 * @param[out] usp      pointer to the @p UartStream object to be initialized
void usObjectInit(UartStream *usp) {
  uint32_t div;
  usp->vmt = &vmt;
  /* Enters the configuration mode.*/
  LINFlexD_2.LINCR1.R  = 1;                     /* INIT bit.                */
  /* Configures the LINFlex in UART mode with all the required
     parameters.*/
  LINFlexD_2.UARTCR.R  = SPC5_UARTCR_UART;      /* UART mode FIRST.         */
  LINFlexD_2.UARTCR.R  = SPC5_UARTCR_UART | SPC5_UARTCR_TFBM |
                         SD_MODE_8BITS_PARITY_NONE;
  div = SPC5_LINFLEX2_CLK / 38400;
  LINFlexD_2.LINFBRR.R = (uint16_t)(div & 15);  /* Fractional divider.      */
  LINFlexD_2.LINIBRR.R = (uint16_t)(div >> 4);  /* Integer divider.         */
  LINFlexD_2.UARTSR.R  = 0xFFFF;                /* Clearing UARTSR register.*/
  LINFlexD_2.LINIER.R  = 0;                     /* No interrupts enabled.   */
  /* Leaves the configuration mode.*/
  LINFlexD_2.LINCR1.R  = 0;
  LINFlexD_2.UARTCR.B.TxEn = 1;
 * @file    uartstream.h
 * @brief   UART stream structures and macros.
#ifndef _UARTSTREAM_H_
#define _UARTSTREAM_H_
/* Driver constants.                                                         */
/* Driver pre-compile time settings.                                         */
/* Derived constants and error checks.                                       */
/* Driver data structures and types.                                         */
 * @brief   @p UartStream specific data.
#define _uart_stream_data                                                   \
  _base_sequential_stream_data
 * @brief   @p UartStream virtual methods table.
struct UartStreamVMT {
  _base_sequential_stream_methods
 * @extends BaseSequentialStream
 * @brief   UART stream object.
typedef struct {
  /** @brief Virtual Methods Table.*/
  const struct UartStreamVMT *vmt;
  _uart_stream_data
} UartStream;
/* Driver macros.                                                            */
/* External declarations.                                                    */
#ifdef __cplusplus
extern "C" {
  void usObjectInit(UartStream *usp);
#ifdef __cplusplus
#endif /* _UARTSTREAM_H_ */
JoVM
Re: ITM stream
Post by JoVM »
The ITM stream object is finished. Offcourse, no need to use a queue. Straight banging the ITM port in the stream methods.
Tnx!
JoVM
Re: ITM stream
Post by JoVM »
FYI zipped ITM trace stream.
Tnx!
RT-STM32F411RE-NUCLEO-ITM.zip
ITM_stream
(12.8 KiB) Downloaded 389 times
Re: ITM stream
Thanks, how the output is handled by OpenOCD?
JoVM
Re: ITM stream
Post by JoVM »
OpenOCD 8.0 on stimulus port 0 works. ST-LINKv2 firmware on the boards should be at least JTAG v17!!
russian
Has thanked: 16 times
Been thanked: 14 times
Re: ITM stream
Post by russian »
JoVM wrote:FYI zipped ITM trace stream.
Tnx!
Would you expect this to work on stm32f407, or is it different initialization sequence?
I think I've just tried your code on stm32f407 and it did not send anything to ST Link Utility SWV. Would you expect SWV to receive data stream?
