Hi all,
After trying to implement the clean shutdown of ChibiOS (before enabling a bootloader) I have run into a function I cannot find.
In the guide here (even though it is for an old version) http://chibios.org/dokuwiki/doku.php?id ... os:stop_os the function stop_system_timer(); seems to disable the systick, is this correct?
The thing is that I look a lot in the 3.0.0 code but I cannot find a function for this. Does it exist?
If not, can it be added? It seems very strange that the user should disable something manually that the OS started automatically.
Just a chSysDisableSystemTimerI or something like that.
Best Regards
Emil
ChibiOS 3.0.0 clean shutdown?
Re: ChibiOS 3.0.0 clean shutdown?
Hi Giovanni, thanks for the reply!
Could you please elaborate?
Because when I look at the function there are two warning signs:
1. I am using systick, so this warning seems to apply to me.
2. It does not seem to disable systick:
Should this function not be something like this to differentiate ticked and tickless mode:
Best Regards
Emil
* @note This functionality is only available in free running mode, the
* behavior in periodic mode is undefined.2. It does not seem to disable systick:
static inline void st_lld_stop_alarm(void) {
STM32_ST_TIM->DIER = 0;
}Should this function not be something like this to differentiate ticked and tickless mode:
#if OSAL_ST_MODE == OSAL_ST_MODE_FREERUNNING
/* Free running counter mode.*/
#endif /* OSAL_ST_MODE == OSAL_ST_MODE_FREERUNNING */
#if OSAL_ST_MODE == OSAL_ST_MODE_PERIODIC
/* Periodic systick mode, the Cortex-Mx internal systick timer is used
in this mode.*/
SysTick->CTRL = 0;
#endif /* OSAL_ST_MODE == OSAL_ST_MODE_PERIODIC */
}Best Regards
Emil
It works in tickless mode only.
There is no way to stop the systick timer unless you stop it manually. I will look into this after 3.0 release.
