DHCP client issues
ulikoehler
DHCP client issues
Post by ulikoehler »
Since ChibiOS 2.6 I have had issues with the lwIP DHCP client not working properly. I believe this is the case because the lwip functions dhcp_start() and dhcp_stop() are never called in the lwIP binding thread.
I have written a patch that calls them when an interface comes up / down. I have tested them successfully on an Olimex E407 and used this code in multiple projects, however I'd like to hear your comments about it.
Change: In lwipthread.c, replace
        if (current_link_status)
          tcpip_callback_with_block((tcpip_callback_fn) netif_set_link_up,
                                     &thisif, 0);
        else
          tcpip_callback_with_block((tcpip_callback_fn) netif_set_link_down,
                                     &thisif, 0);
by
        if (current_link_status) {
                                     &thisif, 0);
          dhcp_start(&thisif);
        } else {
                                     &thisif, 0);
          dhcp_stop(&thisif);
Best regards, Uli
Re: DHCP client issues
Are those supposed to be there even if DHCP is not used?
ulikoehler
Thanks Giovanni - you are right, they should not be active in that case. Here's the fixed version:
                                     &thisif, 0);
#ifdef LWIP_DHCP
        } else {
                                     &thisif, 0);
#ifdef LWIP_DHCP
          dhcp_stop(&thisif);
Best regards
ulikoehler
Correction: It should be this way because LWIP_DHCP is defined as 1 or 0 and not undefined:
                                     &thisif, 0);
#if LWIP_DHCP
        } else {
                                     &thisif, 0);
#if LWIP_DHCP
          dhcp_stop(&thisif);
Best regards
Committed.
ulikoehler
Thanks for merging, Giovanni!
DHCP works perfectly for me now. I noticed, however, that GCC shows a warning that dhcp_start and dhcp_stop are not defined. I might have patched a #include into my lwIP at some point which hid the error from me.
Although it is not functionally required unless someone uses -Werror like flags, I think we should add
#if LWIP_DHCP
#include <lwip/dhcp.h>
somewhere in the include section of lwipthread.c
Best regards, Uli
I committed the change.
