Moderators: RoccoMarco , lbednarz , tfAteba
JoVM
Posts: 89 Joined: Thu Mar 12, 2015 12:13 pm
Post
by JoVM » Thu Apr 02, 2015 9:05 am
@previous post:I gave up on the libgc alloc functions because it's returning NULL pointers.
But I notice chibiOS is providing a heap alloc function I want to try.
Following code blocks my core:
typedef struct { int data; }Element; typedef struct { int current; int size; int increment_rate; Element* elements; }DeviceList; void initWithSizeAndIncRate(DeviceList* const list, int size, int rate) { list->size = size; list->increment_rate = rate; list->elements = (Element*) chHeapAlloc( NULL, list->size * sizeof(Element)); list->current = -1; }I just want to allocate 16 blocks of size Element on the heap.
Posts: 14895 Joined: Wed May 27, 2009 8:48 am
Has thanked: 1202 times
Been thanked: 997 times
Post
by Giovanni » Thu Apr 02, 2015 9:07 am
Define "block", an assertion? a crash? and endless loop somewhere? Giovanni
JoVM
Post
by JoVM » Thu Apr 02, 2015 9:28 am
@Giovanni: It wan't return from this code:
after the while loop in chHeapAlloc().
Post
by Giovanni » Thu Apr 02, 2015 9:38 am
Could you provide a stack trace after stopping execution? Please make sure to enable checks, assertions, stack check and state checker in chconf.h. Giovanni
JoVM
Post
by JoVM » Thu Apr 02, 2015 9:46 am
Do I need to use chHeapObjectInit before allocation? @ps: I'm not using gdb now. Only SWV ITM trace. I need to look if I can make a trace in st utility.
Post
by Giovanni » Thu Apr 02, 2015 11:22 am
No need to init because you are using the default heap (NULL as first paramenter). Giovanni
JoVM
Post
by JoVM » Thu Apr 02, 2015 11:32 am
My debug output:
$ arm-none-eabi-gdb ch.elf GNU gdb (GNU Tools for ARM Embedded Processors) 7.8.1.20141128-cvs Copyright (C) 2014 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "--host=i686-w64-mingw32 --target=arm-none-eabi". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://www.gnu.org/software/gdb/bugs/>. Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/>. For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from ch.elf...done. (gdb) target extended localhost:4242 Remote debugging using localhost:4242 0x08001148 in _heap_init () at ../../../os/rt/src/chheap.c:95 95 chMtxObjectInit(&default_heap.h_mtx); (gdb) backtrace #0 0x08001148 in _heap_init () at ../../../os/rt/src/chheap.c:95 #1 0xffffffff in ?? () Backtrace stopped: previous frame identical to this frame (corrupt stack?) (gdb)
JoVM
Post
by JoVM » Thu Apr 02, 2015 12:34 pm
@Giovanni: discard the above.
This is the stepping through the program:
Breakpoint 1, chMtxUnlock (mp=mp@entry=0x200011a8 <default_heap+16>) at ../../../os/rt/src/chmtx.c:319 319 thread_t *ctp = currp; (gdb) next 318 void chMtxUnlock(mutex_t *mp) { (gdb) next 319 thread_t *ctp = currp; (gdb) step 324 chSysLock(); (gdb) step chSysLock () at ../../../os/rt/src/chmtx.c:324 324 chSysLock(); (gdb) step port_lock () at ../../../os/rt/src/chmtx.c:324 324 chSysLock(); (gdb) step __set_BASEPRI (value=32) at ../../../os/ext/CMSIS/include/core_cmFunc.h:546 546 __ASM volatile ("MSR basepri, %0" : : "r" (value) : "memory"); (gdb) step chMtxUnlock (mp=mp@entry=0x200011a8 <default_heap+16>) at ../../../os/rt/src/chmtx.c:342 342 if (chMtxQueueNotEmptyS(mp)) { (gdb) step chMtxQueueNotEmptyS (mp=<optimized out>) at ../../../os/rt/src/chmtx.c:342 342 if (chMtxQueueNotEmptyS(mp)) { (gdb) step queue_notempty (tqp=<optimized out>) at ../../../os/rt/include/chschd.h:600 600 return (bool)(tqp->p_next != (thread_t *)tqp); (gdb) step chMtxUnlock (mp=mp@entry=0x200011a8 <default_heap+16>) at ../../../os/rt/src/chmtx.c:339 339 ctp->p_mtxlist = mp->m_next; (gdb) step 342 if (chMtxQueueNotEmptyS(mp)) { (gdb) step 347 tprio_t newprio = ctp->p_realprio; (gdb) step 349 while (lmp != NULL) { (gdb) step 353 if (chMtxQueueNotEmptyS(lmp) && (gdb) step chMtxQueueNotEmptyS (mp=0x80004d1 <_unhandled_exception>) at ../../../os/rt/src/chmtx.c:353 353 if (chMtxQueueNotEmptyS(lmp) && (gdb) step queue_notempty (tqp=0x80004d1 <_unhandled_exception>) at ../../../os/rt/include/chschd.h:600 600 return (bool)(tqp->p_next != (thread_t *)tqp); (gdb) step chMtxUnlock (mp=mp@entry=0x200011a8 <default_heap+16>) at ../../../os/rt/src/chmtx.c:353 353 if (chMtxQueueNotEmptyS(lmp) && (gdb) step 354 (lmp->m_queue.p_next->p_prio > newprio)) { (gdb) step _unhandled_exception () at ../../../os/common/ports/ARMCMx/compilers/GCC/vectors.c:79 79 ; (gdb) step
Post
by Giovanni » Thu Apr 02, 2015 12:37 pm
Are the debug option that I mentioned before enabled? Giovanni
JoVM
Post
by JoVM » Thu Apr 02, 2015 12:54 pm
Sorry forgot.
(gdb) next 185 H_UNLOCK(heapp); (gdb) step chMtxUnlock (mp=mp@entry=0x20001630 <default_heap+16>) at ../../../os/rt/src/chmtx.c:319 319 thread_t *ctp = currp; (gdb) step 322 chDbgCheck(mp != NULL); (gdb) step 319 thread_t *ctp = currp; (gdb) step 322 chDbgCheck(mp != NULL); (gdb) step 324 chSysLock(); (gdb) step chSysLock () at ../../../os/rt/src/chmtx.c:324 324 chSysLock(); (gdb) step port_lock () at ../../../os/rt/src/chmtx.c:324 324 chSysLock(); (gdb) step __set_BASEPRI (value=32) at ../../../os/ext/CMSIS/include/core_cmFunc.h:546 546 __ASM volatile ("MSR basepri, %0" : : "r" (value) : "memory"); (gdb) step chSysLock () at ../../../os/rt/include/chsys.h:300 300 _stats_start_measure_crit_thd(); (gdb) step _stats_start_measure_crit_thd () at ../../../os/rt/src/chstats.c:95 95 chTMStartMeasurementX(&ch.kernel_stats.m_crit_thd); (gdb) step chTMStartMeasurementX (tmp=0x200014f0 <ch+1200>) at ../../../os/rt/src/chtm.c:116 116 tmp->last = chSysGetRealtimeCounterX(); (gdb) step port_rt_get_counter_value () at ../../../os/rt/ports/ARMCMx/chcore_v7m.h:547 547 return DWT->CYCCNT; (gdb) step chTMStartMeasurementX (tmp=0x200014f0 <ch+1200>) at ../../../os/rt/src/chtm.c:116 116 tmp->last = chSysGetRealtimeCounterX(); (gdb) step chSysLock () at ../../../os/rt/include/chsys.h:301 301 _dbg_check_lock(); (gdb) step _dbg_check_lock () at ../../../os/rt/src/chdebug.c:152 152 if ((ch.dbg.isr_cnt != 0) || (ch.dbg.lock_cnt != 0)) { (gdb) step 155 _dbg_enter_lock(); (gdb) step chMtxUnlock (mp=mp@entry=0x20001630 <default_heap+16>) at ../../../os/rt/src/chmtx.c:326 326 chDbgAssert(ctp->p_mtxlist != NULL, "owned mutexes list empty"); (gdb) step 327 chDbgAssert(ctp->p_mtxlist->m_owner == ctp, "ownership failure"); (gdb) step chSysHalt (reason=reason@entry=0x80036f0 <__func__.6584> "chMtxUnlock") at ../../../os/rt/src/chsys.c:164 164 ch.dbg.panic_msg = reason; (gdb) step 168 } (gdb) step
