im using stm32f103 , i set EXTI to measuring PWM input data. im using EXTI for PB3 , PB4 , PB5 and PB6 . but all of configuration is same as each other and all of pins works and i can calculate pulse width easily Except PB3 .
based on board.h all of these pin set same as each other too.
/* 8 - Digital input with PullUp or PullDown resistor depending on ODR.*/
#define VAL_GPIOBCRL 0x88888888 /* PB7...PB0 */
#define VAL_GPIOBCRH 0xB4884B88 //0xB4B88888 /* PB15...PB8 */
#define VAL_GPIOBODR 0xFFFFFFFF
the only different between this pin and other is that it's using for JTDO . from your sight is it could be the problem ??
is there any way to use this pin as normal pin ??
thanks in advace
MA
